Nuheat Heating Pad Continuity - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 10:07 AM   #1
Nuheat heating pad continuity
I have a Nuheat underfloor heating being installed.
I checked resistance and continuity before installation .
I had it installed by a contractor. Now I rechecked it after install and
Have the proper resistance. I cannot get my meter to read any continuity.
One lead to the grey ground wires and one to the white lead. My meter does. Ot have a sound alert but I believe it should go fr reading one to zero when testing.
Am I having a brain cramp Have I done something wrong doing the test.
Finnigan is offline   Reply With Quote
Old 03-20-2012, 10:20 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Do you have any other wires than the gray and white
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-20-2012, 10:24 AM   #3
Licensed electrician
Rewards Points: 1,622
How do the resistance reading compare to what was taken when the mat was right out of the box?
Old 03-20-2012, 10:57 AM   #4
Nuheat
The resistance reads the same 60 ohms
Old 03-20-2012, 10:59 AM   #5
The other wire is the hot black
Old 03-20-2012, 11:15 AM   #6
rrolleston's Avatar
You should be measuring resistance from black to white. And black to gray and white to gray should be open.
Old 03-20-2012, 11:20 AM   #7
I measured resistance using black to white and read 60 ohms which is correct, it's grey to black or white I'm not getting a zero reading as apprised to the 1 reading you get when not testing
Tags
continuity
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 08:26 PM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 01:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 05:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 07:27 PM
Central Heating Frustration SassySue General DIY Discussions 4 11-29-2007 06:46 AM
