NuHeat 240V Thermostat Hookup - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 12:26 PM   #1
NuHeat 240V Thermostat hookup
The Instructions for the NuHeat Solo Thermostat show the Feed wire only having a Hot wire, a Ground Wire and a Neutral Wire.... I'm running a 240V feed and it of course has 2 feed wires, a neutral and a ground. How is this supposed to be hooked up? I have a 240V compatible Thermostat, NuHeat Solo.
Gamblor1069 is offline   Reply With Quote
Old 09-12-2010, 12:33 PM   #2
www.No-Curb.com
JohnFRWhipple's Avatar
Be careful here...
Sounds like you have the wrong thermostat.
These thermostats are sold as either 120 or 240 volt systems most times. Make sure you do this right.
You can loose your home if you get it wrong.
Where the wires toned?
Is the wire the right guage?
Did your inspector see this step? - It's a required inspection...
JW
JohnFRWhipple is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Two 120v Nuheat mats wired in series for 240v circuit? chrispy35 Electrical 18 04-26-2010 11:16 PM
Warm tiles 240v thermostat cybertone Electrical 41 01-07-2010 09:07 PM
added o.s.wood boiler,how to hookup 2nd thermostat geobckmstr HVAC 0 11-16-2009 02:13 PM
