Nuetral Bus Has Been Attached To A Metal Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 09:47 PM   #1
Nuetral bus has been attached to a metal panel
What would you do to fix a nuetral bus attached to a metal panel?
preachernw is offline   Reply With Quote
Old 09-23-2012, 09:52 PM   #2
Licensed electrician
Rewards Points: 996
How is the bus broken? It probably needs to be replaced.
Old 09-23-2012, 09:52 PM   #3
kevinp22's Avatar
if its a main panel it should be bonded to the panel as well as any other neutral/grounding busses
so, first question is is it a main?
best to post a picture if the answer is no or not sure
kevinp22 is offline   Reply With Quote
Adding panel insulation and metal roofing Ben gilmore Roofing/Siding 1 04-02-2012 08:24 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
sub panel metal studs donaldbyrd Electrical 4 01-25-2008 05:50 PM
