Nowhere To Mount Switch Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 10:23 PM   #1
Nowhere to mount switch box
I am trying to install a metal three-gang switchbox in a wall that is plaster over concrete. I had to cut the hole larger than the switch box in order to run some new cables.The problem is, I have no way to secure the switch box. There are no studs, and the concrete crumbles if I try to drill or screw into it.
I thought about applying plaster into the hole and using that as a sort of "glue" to hold the box in. but I'm not sure if that's the best approach.
any suggestions would be much appreciated.
DaveJH is offline   Reply With Quote
Old 08-17-2012, 11:17 PM   #2
Master Electrician
If the concretes crumbling when you drill it you've got bigger problems than no switch box support.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-17-2012, 11:54 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Cut the opening larger to expose a stud, mount the box to the stud, then patch around the box.
Old 08-18-2012, 08:36 AM   #4
Rewards Points: 1,294
Sometimes I wonder if people read the prior posts before they comment
danpik is offline   Reply With Quote
Old 08-18-2012, 12:44 PM   #5
Rewards Points: 78
Mix up some mortar mix and get some newspaper. Fill the bottom of the hole with newspaper. Then fill the hole with mortar mix. Push box with wires back into the hole. Mortar mix should ooze out the sides for a good hold.
Once it is semi dry. Take a damp sponge and smooth out all the rough edges and make it look good.
J. V. is online now   Reply With Quote
Old 08-18-2012, 10:42 PM   #6
thanks J.V.
I'll give it a shot
Old 08-18-2012, 10:49 PM   #7
k_buz's Avatar
Maybe you should read a little closer...if it was truly plaster over concrete, why would he be cutting a hole?
Old 08-18-2012, 11:02 PM   #8
" Euro " electrician
frenchelectrican's Avatar
I did take a closer look the photo what the OP was refering and I have to blow this photo up and I can see BX's there and I may say this is a large brick type wall so that may expain why the BX is there if this wall is soild there is no way you can snake them in without breaking or "trenching " the rest of the pathway.
I will just use the liquid nails and use a bit and let set for couple minutes then stick the box in the place and hold it for a minuite or two it will lock in pretty good even cement glue stuff work as well.
Merci,
Marc
Old 08-19-2012, 01:01 AM   #9
How about a metal plate....say 12"x12" out of 16g galv? Cut a hole in it the size of the box...mount box to plate...mount plate to wall....a screw at each corner....maybe use liquid nails between the plate and the wall....
Sort of overkill.....but I bet it would stay put....
jeepdawg is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
mount a new wall switch next to an old one denemante Electrical 4 09-28-2011 08:32 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
