NOW I'm Confused! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 08:28 PM   #1
the Musigician
DangerMouse's Avatar
Question
NOW I'm confused!
i'm getting conflicting answers here, i need to fill the holes in the floor i drilled to run wires, one guy says caulk is ok, another says there's a special draftstop product. what is it and where do i have to go to get it? this inspector WILL hit me if i don't get it right.
tnkx! DM
Old 07-20-2008, 08:41 PM   #2
Is this inside of a wall? If you need to maintain a fire stop, you should use something like this:
http://contractorservices.homedepot....3-a74473812da4
jerryh3 is offline   Reply With Quote
Old 07-20-2008, 08:56 PM   #3
the Musigician
not firestop, just air flow from crawl space to inner walls above
Old 07-20-2008, 08:57 PM   #4
the Musigician
and the link did not work... lol just not my day
Old 07-20-2008, 09:23 PM   #5
Try this link:
http://solutions.3m.com/wps/portal/3...glZCBZZT4NCJbl
If it's just air penetration you should be able to use caulk or spray foam. Just check the label for interactions with wires or pipes.
Old 07-20-2008, 09:35 PM   #6
Power Gen/RS Engineer
Rewards Points: 566
Why not just call your inspector and ask him what he expects to see? If it's just for airtightness/keeping critters out, the spray foam is IMO the way to go. Use the Dap product instead of the Greatstuff; it's water based so it cleans up easy.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-20-2008, 09:48 PM   #7
You should use a fire rated caulk... or FR drywall compound.,,,
The idea is to isolate the smoke, air , heat and flames from traveling through the wall cavities and into the attic area. penetrations at wires and pipes, etc.
Build safe.....
jerryh3 is on track....
Big Bob is offline   Reply With Quote
Old 07-20-2008, 10:02 PM   #8
Electrician
You need to check with local codes, In my area we use the IRC, International Residential Code. So, the intergrity of all firestops, fireblocks and draftstops must be maintained.
chris75 is offline   Reply With Quote
Old 07-20-2008, 10:13 PM   #9
Rewards Points: 566
This is what I'm held to as well which is why I usually say, "when in doubt, call the inspector."
Old 07-21-2008, 04:45 PM   #10
the Musigician
thanks for all the input, i think i need to go with a fire rated caulk soooo, does anyone have a brand name? my wife needs to stop on the way home and pick it up as we live in the sticks. i need to tell her exactly what to get or she'll come home with another mule.
thanks again!
DM
Old 07-21-2008, 05:41 PM   #11
3-M Fire Dam 150+ is what we use.
Cajun1 is offline   Reply With Quote
Tags
draftstop
Attic Ventilation. Somewhat confused! ridgevilleac Roofing/Siding 2 07-06-2008 05:10 PM
I'm confused, pls help! spanky28 Electrical 6 06-09-2008 10:56 AM
Confused.....Halo H7ICT Recessed Lighting Question tigerbalm2424 General DIY Discussions 5 01-09-2008 08:21 AM
Confused about Pex mw6263 Plumbing 14 12-06-2007 05:31 PM
