Novice Question Regarding GCFI - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 09:16 PM   #1
novice question regarding GCFI
Hi. I am new to wiring, so please excuse my ignorance. I have a 20amp circuit (double 20 breaker), which I am trying to connect in the following configuration: >> means flow of power
20 amp breaker to standard outlet >> junction box split to two 12-2 >> the first going to a 15amp GCFI then to a standard outlet. the second is going to another 15amp GCFI.
The first outlet in the circuit that provides power to the junction box works BUT the yellow lights on both GCFIs come ON, but none of the three outlets are working. I am obviously doing something wrong - can someone please provide me with some education here? Thank you!!
blackfrancis is offline   Reply With Quote
Old 06-02-2012, 09:18 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
I am totally confused. What wire did you run to what?
WHY is this a double-pole breaker? Or is it a twin?
Old 06-02-2012, 09:25 PM   #3
It is a double pole i think (says two one pole, it's older). it goes first to an outlet, then from that outlet to a junction where it is split into two 12-2 wires. one is going to a 15 amp gcfi, then to a standard outlet. the other goes directly to a gcfi. does this make sense?
Old 06-02-2012, 09:29 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What wires did you put on the breaker.
(I am really hoping I am wrong and you did not do what I am picturing in my head)
The Following User Says Thank You to k_buz For This Useful Post:
rjniles (06-02-2012)
Old 06-02-2012, 09:36 PM   #5
From the breaker is 12-2. The whole circuit is 12-2. From the breaker to the first outlet is existing wire. The outlets that were coming off of the junction were formerly two standard outlets, and I wanted to add two GCFis and 1additional outlet. The former configuration worked. When I installed the GCFIs it stopped working. The lights come on they are getting power I would assume.
Old 06-02-2012, 09:38 PM   #6
k_buz's Avatar
Was the wire leaving the breaker existing, or did you install the breaker and wiring to the breaker new?
Old 06-02-2012, 09:41 PM   #7
The breaker and wire to the breaker are existing. The wire is 12-2
Old 06-02-2012, 10:05 PM   #8
k_buz's Avatar
On the GFI...the incoming power goes to the line side of the GFI and the wire leaving the box goes to the load side. These cannot be interchanged like a normal receptacle.
Old 06-02-2012, 10:59 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
Sounds like he is trying to wire a MWBC. You can't with 12/2 off the 2 pole breaker.
Coastal South Carolina
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
