Novice Electrician (UGH) Replacing Fan/Light Combo Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 04:42 PM   #1
Novice Electrician (UGH) Replacing Fan/Light combo switch
I had a BROUN model 48V switch in the wall that had to paddle switches on it, one for the fan light and one for the fan motor. The switch failed and I bought a new double paddle light. The old Broun switch had 3 posts the bare copper earth ground was shoved back in the electrical box and the white wires are capped behind the switch. There are two black wires (one in the common) and a red wire.
The new switch has a blue post for earth ground and then two posts on each side. When I wire the red and a common on one side with a common on the other, only the fan works. If I switch the common wires from one side to the other, only the light works. What a I doing wrong?
jeffntonya23 is offline   Reply With Quote
Tags
electrical , house , switch , wiring
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
switch outlet combo help- diydamsel Electrical 2 04-03-2010 07:40 AM
Wiring Double Switch fan/light mjbcable Electrical 5 10-18-2009 06:56 PM
Replacing a switch wired in series? bmoorhouse Electrical 11 04-19-2009 07:04 PM
Replacing Dimmer Switch dallas520 Electrical 3 05-15-2005 11:49 AM
