Not Getting 120 Volts From Hot To Neutral, But 120 From Hot To Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 05:53 PM   #1
Rewards Points: 14
Not getting 120 volts from hot to neutral, but 120 from hot to ground
Hello All,
Iím not getting 120 volts across a hot wire (black) to a neutral wire (white). However; I do get 120 volts across the hot wire to a ground wire.
I originally replace my old garbage disposal to one thatís more powerful. The hot, neutral, and ground wires (from disposal) run through the wall and up to a basic on/off switch that has an electrical outlet next to it (both 15 amps). After hooking up the wiring and before replacing back in the wall; both on/off switch and outlet appeared to work fine.
At this point I bought a modern rocker type switch and square-like socket (15 amps) to replace the outdated ones. This is when the outlet and on/switch would not work. After 3 hours of trouble-shooting, I went back to the old on/off switch and socket and still neither will work.
I measured the voltage across the circuit breaker that controls this this wiring and I get 120 volts; however, at the circuitry for this on/switch from hot to neutral, about 2 volts shows on the meter. From hot to a ground wire though, I get 120 volts.
Iíve checked other circuits in my house and get 120 volts from a hot wire to a neutral wire.
Any advice? I sure hope itís something I donít understand.
Thank you,
Jim
Jimmi328 is offline   Reply With Quote
Old 05-10-2013, 05:54 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Hello All,
Thank you,
Jim
You changed the splice...
Old 05-10-2013, 05:55 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
Sounds like you have an open or loose neutral connection somewhere in the circuit. Check all your connections in the neutral path from the disposal back to the panel. There's probably a bad connection there somewhere.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 05-10-2013, 06:13 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,860
By square socket, do ya mean a "decora" receptical. Just as above MP and stick said, bet the neutrals wired in the receptical (or in the switch box) came loose. Try remaking them.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-10-2013, 06:19 PM   #5
joed's Avatar
Rewards Points: 12,922
Tell us what wires are connect to what other wires and switch connections. Then we might be able to tell you what is wrong. Now it sounds like you have an open neutral.
Old 05-10-2013, 06:39 PM   #6
Rewards Points: 14
Yes, the words “Decora” (Leviton) are in fact on both boxes. I had no clue that neutrals could be wired within the socket or how this works. But I have something to research now.
Re-make them? The outlet and switch appear to be all one piece.
I will be more pacific and post pictures Joe, after the weekend when I have more time. There is an additional black wire in this metal box that has no power on it. It’s next to the hot black wire. No clue what it's for.
Thank you all for the input.
Old 05-10-2013, 06:45 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,366
[QUOTE=Jimmi328;1176724]
He doesn't mean remake the recepticules !
He means remake the connecttions to the recepticules !
Take off the wires one by one,
Make sure there clean and in good condition,
Put the wires back were they came from,
make sure there good and tight.
Use screws not back stabs !
Look for any obvious problems.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
MTN REMODEL LLC (05-10-2013)
Old 05-10-2013, 06:49 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'd be curious to know if it is a switch loop coming from the disposal.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (05-10-2013)
Old 05-10-2013, 06:55 PM   #9
[QUOTE=dmxtothemax;1176728]
OP.... Maybe hold up there a minute.... I thought you might be a little more familiar with electrical.
1) DO YOU HAVE YOUR BREAKER OFF FOR THIS CIRCUIT AND ARE YOU SURE?
2) Are you familiar with how to join (splice) wires with a wirenut (the little colored toothpaste-cap looking do-hickey ) that may be in the box.
Old 05-10-2013, 06:57 PM   #10
E2 Electrician
My guess is that he changed the splice.
Old 05-10-2013, 07:13 PM   #11
my bet too .... EDIT: except for the recent post about the renegade black wire
Old 05-10-2013, 07:18 PM   #12
Yes, the words ďDecoraĒ (Leviton) are in fact on both boxes. I had no clue that neutrals could be wired within the socket or how this works. But I have something to research now.
I will be more pacific and post pictures Joe, after the weekend when I have more time. There is an additional black wire in this metal box that has no power on it. Itís next to the hot black wire. No clue what it's for.
But Jimmie... aren't you and Coral Gables closer to the Atlantic?
Good going
Peter
Old 05-10-2013, 07:42 PM   #13
Rewards Points: 14
Switch loop? I probable disconnected this wire and don’t remember how it was wired.
Peter: I made sure the breaker was on when I tested the on/off switch. 120 volts travels from hot to ground but not hot to neutral. Yes, I used the wirenuts to splice wire where necessary and of course turned the breaker off before doing so. (Coral Gables is Miami, Coral Springs is north of Ft. Lauderdale).
Stickboy: Perhaps I missed something while splicing but this concept seems so basic.
Old 05-10-2013, 08:36 PM   #14
Rewards Points: 512
Switch loop? I probable disconnected this wire and donít remember how it was wired.
Jimmy, I may be wrong, but chances are if there's a white wire in a switch box, it's NOT a neutral, and if the white wire is on the switch, it is definitely not a neutral.
PICS?
Installation is the Reverse of Removal.
Old 05-10-2013, 11:48 PM   #15
" Euro " electrician
frenchelectrican's Avatar
Bonjour Jimmi .,
Did you any chance you brought this decora receptale with GFCI verison ? if so you may have the netural in wrong place that what prevent it from running.
However you say this is the only switch that go to the garbage dispoal unit and you have a receptale right next to it ?
If so have you take a photo so we can able assit you on that.
Is other receptales is working as well or is that only one is not working?
And I doubt this is a switch loop but to be on safe side take a photo and count how many cables ( there will be a pair of black et white conductor <wire> for each cable ) then we can able tell where it goes once we get more info.
Merci,
Marc
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Main Breaker Panels - Neutral vs. Earth Ground TomM141 Electrical 3 02-03-2013 05:17 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
