Not Enough Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 11:56 AM   #16
When we were looking at houses to buy I looked at the electric 1st
I wanted a 200a panel...newer wiring...no K&T
I've rewired a lot in this house
Not because I had to.....because I wanted to
Sons bedroom had 2 outlets & one was off the bathroom outlet
That in turn was off a lighting/outlet circuit that was overloaded
Now my sons bedroom has a 20a AFCI circuit & the outlets are spaced no more then 6' apart
Not sure when the 12' spacing went into effect
Old 09-22-2010, 01:03 PM   #17
is it every 12 feet or 6 feet? And yes, if anyone can give me an idea of when that went unto effect that would be very helpful!
beths0704 is offline   Reply With Quote
Old 09-22-2010, 01:06 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
Very basically, it's every 12', and/or 6' from an opening or break in the wall such as a door.
Truly no offense meant, but if this addition was done in 1988, even if it was not done to code, what difference does it make now?
Old 09-22-2010, 01:08 PM   #19
Thanks and I understand your confusion, but I'm a Realtor and the buyer of one of my listings wants the additional outlets added at my Seller's expense, saying it has to be to code. So I'm trying to find out when that code was in effect
Old 09-22-2010, 01:24 PM   #20
Licensed electrician
Rewards Points: 1,758
My situation is a house that had an addition in 1988, screened porch was enclosed, additional outlets were not installed every 6 feet or whatever the current code is...trying to find out they should have been at that time per code. Thanks for the quick response!
This might have been unpermitted work and was never checked for compliance. It may also not meet the definition of a habitable room so the 6/12 spacing would not need to be meet.
Your client is buying a used home. To expect it to be to todays standard seems somewhat over the top.
Old 09-22-2010, 02:00 PM   #21
Thank you, that's what I thought also. My client is the seller and we thought the buyer was being a bit over the top also. Just be glad you aren't privvy to the heat exchanger dilemma!
Thanks again!
Old 09-22-2010, 02:04 PM   #22
1000% agree!
G-D home buyers today want everything for nothing. They want an old home brought up to modern codes. I blame *%#@ home inspectors for much of this twisted mentality.
Tell the buyers this is it. Take it or leave it!
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
