Not Enough Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 08:25 PM   #1
Not enough outlets
Hello. This is my first post so hello to everyone and I hope this works.
I recently moved into a one-bedroom apartment in Manhattan. The apartment is an old pre-war building and, as it turns out, there aren't enough electrical outlets. There's only one in the living room and one in the bedroom. Needless to say that that's not really enough to run an apartment. I've got a lot of extension cords around the place.
I spent about three weeks trying to get someone at the management company to answer my phone calls and today I finally got a call from a supervisor. I explained that the National Electrical Code (NEC) states that there needs to be an electrical outlet not more than 6 feet from any break in a wall such as a doorway or a corner and no two outlets on the same wall can be more than 12 feet apart. He said that he understood and that he was familiar with the code but that he was under no obligation to install more outlets in my apartment because the building was constructed before the NEC went into effect. His proposed solution to the problem was to install wire molds so that I could run my extension cords along the walls and have them be covered up. He admitted that he was uncertain as to the legality of the solution but since he was unwilling to open a wall in order to install new outlets, that was the best solution he could offer.
Does is anybody out there familiar with the electrical code in New York City? Any suggestions? I don't want to run too many extension cords for obvious reasons and I'm not sure what cards to play with this company since I'm no lawyer. I'd like to find out what my options are.
nyctenant
nyctenant is offline   Reply With Quote
Old 08-11-2010, 08:33 PM   #2
Older installations are not required to be updated to meet todays code
In some cases they are - installing Smokes is one such requirement
About the only card to play is that you will be moving
Old 08-11-2010, 08:34 PM   #3
Superintendent
Mudpad's Avatar
I don't know about your area but in TN he would have no obligation to do anything. But if he does do something it needs to meet the code. He would be better off not to touch it.
Mudpad is offline   Reply With Quote
Old 08-11-2010, 09:14 PM   #4
Electrician
Proby's Avatar
I hate to say it, but you're SOL.
Extension cords are a leading cause of residential fires so be careful. Don't span them underthings that could crush them and make sure no one is going to step on them.
There are surface mount solutions, but you would need both permission from the management and a licensed electrician.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-12-2010, 11:09 AM   #5
Thanks, everyone, for the quick replies! Too bad that I'll be SOL on this one. I'll definitely let you know if any new revelations come up because of this...just let it be a lesson for anyone who might rent in an older building, particularly in NYC. Any suggestions on the wire molding solution? Thanks again.
Old 08-12-2010, 11:45 AM   #6
Electrician
Proby's Avatar
Unfortunately, the only Wiremold you can use is something to support extension cords as your manager specified.
To run Wiremold with receptacles around the room would most likely fall under building wiring, especially in Manhattan.
Old 08-12-2010, 12:43 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Didn't you notice this before you moved all your furniture in?
Or even before you signed the lease?
Old 08-12-2010, 12:47 PM   #8
Electrician
Proby's Avatar
Petey, when you look at a new house, what's the first thing you look at? The electric, right? Me too.
But these other people just don't care, it's a shame
Old 08-12-2010, 01:40 PM   #9
Totally screwed together
You might want to look for extra long power strips. These strips have a 4' to 6' long cord on them, then the strip itself is about 4' long. This is great for places like desks and kitchens, where you might have a bunch of those wall wart transformers hanging off to recharge phones and other low voltage items. They even have ears on them so you can easily screw them into the wall.
xxPaulCPxx is offline   Reply With Quote
Old 08-12-2010, 01:57 PM   #10
Rewards Points: 590
Protect the cords by covering them with the floor molding that you can get at office supply stores (Office Max, Staples) if there is ANY chance anyone could step on them. It looks better too.
operagost is offline   Reply With Quote
Old 08-12-2010, 02:34 PM   #11
Tizzer's Avatar
Rewards Points: 452
Are they even grounded receptacles? I rented a home a long time ago that had all 2 prong outlets.
I'm thinking the same as the others have mentioned. The complex is grandfathered from new codes. If he opened up the walls for new wiring he'd probably have to bring the whole complex up to date...... and won't do that for one tenant.
Tizzer is offline   Reply With Quote
Old 08-12-2010, 03:29 PM   #12
Thing is, in today's world you would think that most folks would notice. I know with a lot of people I do walk-thrus with in newly acquired homes this is one of the first things they mention.
Old 09-22-2010, 12:18 PM   #13
NEC dates?
So if the older houses do not have to have the multiple outlets on the wall, what is the date that this code went into effect, so we'll know which older houses are "grandfathered" and which are not?
beths0704 is offline   Reply With Quote
Old 09-22-2010, 12:46 PM   #14
Licensed electrician
Rewards Points: 1,038
The only codes the building are required to meet are the ones that have been adopted and enforced at the time of construction. There are some exceptions to this like for receptacle replacement.
The electric code changes every 3 years, but not all areas adopt the most recent.
beths0704 (09-22-2010)
Old 09-22-2010, 12:54 PM   #15
My situation is a house that had an addition in 1988, screened porch was enclosed, additional outlets were not installed every 6 feet or whatever the current code is...trying to find out they should have been at that time per code. Thanks for the quick response!
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 08:23 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
