Not Enough Electricity To Run Appliances - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 09:39 AM   #1
Not enough electricity to run appliances
My daughter just bought a house. It was inspected and the inspector said the wiring was great. However, they notice that when the microwave runs it starts out good then immediately seems to lower power. They plugged in an Edenpure heater last night and couldn't draw enough power for it to run. Does anyone know what causes this to happen? Did they get screwed by the inspector?? Thanks for any help.
oumom4 is offline   Reply With Quote
Old 10-01-2011, 09:41 AM   #2
Sparky
Rewards Points: 510
call your power company. it sounds like you may have a loose neutral
Techy is offline   Reply With Quote
Old 10-01-2011, 10:08 AM   #3
Licensed electrician
Rewards Points: 1,502
Does this happen all over the house or just on one circuit? All over the house signals a problem either in your panel or in the power company wiring. If only one circuit the problem is either a bad splice or connection in the circuit or panel.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
SD515 (10-02-2011), whatsup (10-01-2011)
Old 10-01-2011, 10:33 AM   #4
Rewards Points: 1,500
A typical electrical inspection is visual. They do a spot check for amateurish attempts to repair or extend wiring, deterioration, obsolete parts, damage from overloading, and insufficient overall capacity.
The inspector might not do a load test (perhaps using voltmeter and hair dryer) which is needed to make the problem you describe show up. Turning on just a few lights might not make the problem show up.
Old 10-01-2011, 06:00 PM   #5
Check connection at receptacles and panel for tightness, Loose connections represent 80% of my service business. rookies! Turn off power, IF YOUR NOT A SEASONED PROFESSIONAL!
whatsup is offline   Reply With Quote
Old 10-01-2011, 09:57 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,190
The inspector did not test the system under heavy load !
You most likely have a bad/loose connection somewhere,
Or pocos system is short on power.
These types of things dont show up on test,
unless there is a solid load on the system.
So my guess is he just put a volt meter on it,
And because there was probably only a light load
on the system at that point, the fault was not clearly evident.
dmxtothemax is offline   Reply With Quote
Old 10-02-2011, 11:08 AM   #7
Rewards Points: 1,192
That is your typical home inspection. Got a home warranty from realtor?
bobelectric is offline   Reply With Quote
Old 10-02-2011, 12:00 PM   #8
Rewards Points: 6,652
Inspector did not screw up. Before she even finalized the contract, there should have been an electrician tp inspect everything.
Now, at this point, her hands are tied and it will be really gard for any recourse againts the original sellers, unless it was a bank and she is on her own.
Old 10-02-2011, 12:05 PM   #9
Warranties are only good to wipe yoir rear with. What she needs to do, is lawyer up. And as for the OP stating that the Poco is using the excuse of being short on power, is more on the lines that they do not care.
If the POCO does not take care of their end, they will be there, when the house catches on fire, if the problem becomes really bad, or it causes problems with their system, due to how it will cause load problems on the distribution system.
Old 10-02-2011, 12:30 PM   #10
The electric company never runs out of power for just a few houses, that kind of voltage drop would be due to a defect in the lines.
Running out of power shows up a a brownout that affects almost everyone in the neighborhood if not in the town and the voltage is just a little low (like less than ten percent). Or running out of power results in some areas being blacked out using automatic sensors and switches.
Old 10-02-2011, 01:09 PM   #11
Problem is, a lot of those that got into home inspection at the downturn, are green, and do not know a lot of this stuff, nor do they think that they should take the risk. Home Inspection is one of those areas that those doing it, should not take short cuts, just so they can collect a paycheck.
Old 10-02-2011, 01:12 PM   #12
Before Ameren took over CILCO (Central Il. Light & Gas Co.), the distribution system was so bad, that brownouts were notorious, and still are with their system. To prove to CILCO, that we had a problem with our house, we hooked up a meter and took hourly readings for a couple of days, then after giving that to them, they fixed the problem.
I am with you Allan, whoever the OP spoke with at the utility, is blowing smoke, and should not even be tasked with working for them, if they do not know how the service works.
Using the correct fuses in appliances? razorcut Electrical 2 06-11-2011 09:38 AM
European Appliances... A Question of Amps and Watts??? Dazzlin Electrical 3 08-09-2010 09:06 AM
No electricity in half the room (somewhat complicated) jimbob8690 Electrical 1 07-13-2010 03:23 PM
New stainless appliances poolecw Appliances 2 12-04-2008 02:23 PM
Are European appliances really that much better? home_improver Appliances 2 09-30-2008 06:06 PM
