Old 10-08-2008, 12:16 PM   #1
Question
Not able to secure vanity light to back plate with any screws
can't secure the new light so i put the old light back. thx for all of you.
luvxyz is offline   Reply With Quote
Old 10-08-2008, 01:35 PM   #2
Do you have an electrical box in there?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 01:41 PM   #3
Question
Yes, there is a box, but there is only two holes and there was nothing behind it. No wood, no dry wall. It's all empty; that's the reason why I can't screw anything into it. There are two holes in the middle, but there are metal beind it blocking the way, so I can't scew anything there either. I added a picture of the box in the album. Please take a look it.
Old 10-08-2008, 02:14 PM   #4
Well I am not sure what is going on here as it is not all that clear.
If the light is small and doesn't weigh much you can use a retrograde box that will hold weight if installed correctly. These boxes have "wings" on them that will tighten up against the wall board and act as anchors.
Old 10-08-2008, 02:28 PM   #5
Electrical Contractor
You will have to cut the screws to make them shorter. It happens all the time.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-08-2008, 03:46 PM   #6
I think I know what you are refering to. Unfortunatly I have a havy light.
Old 10-08-2008, 05:06 PM   #7
Moderator
Termite's Avatar
The box in the picture is a pancake box. It is a very common box, and is made of metal. What you need is a mounting strap (or "hickey") to accommodate the light fixture screws. The hickey screws to the box.
You should be using machine-thread screws...You are, right?
Old 10-08-2008, 05:09 PM   #8
Moderator
Termite's Avatar
If the pancake box isn't secured to anything, it should be easy to remove and replace with a box that will physically mount to the sheetrock with the aforementioned little plastic wings. There are other configurations as well.
Old 10-08-2008, 06:42 PM   #9
It's a pan box for a reason. There will be a stud behind it.
Like jbfan said, you just need the right length screws (8/32's) that won't hit the back of the box.
If that is a FAN pan box, the screws will be 10/32's and will slip thru the tabs and screw into the back of the box.
220/221 is offline   Reply With Quote
Old 10-08-2008, 07:30 PM   #10
Moderator
Termite's Avatar
I'd certainly hope so too, but the OP indicated that there wasn't anything behind it.
Old 10-08-2008, 08:18 PM   #11
He was confused
Tags
install, light, plate, problem, scewing
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Safety Concern related to bathroom light fixture sooner2k1 Electrical 3 01-10-2008 09:57 PM
Vanity light bathroom drill hole concern sooner2k1 Plumbing 1 01-10-2008 08:04 AM
