-   -   Not able to secure vanity light to back plate with any screws (http://www.diychatroom.com/f18/not-able-secure-vanity-light-back-plate-any-screws-29576/)
luvxyz 10-08-2008 11:16 AM
can't secure the new light so i put the old light back. thx for all of you.
Marvin Gardens 10-08-2008 12:35 PM
Do you have an electrical box in there?
luvxyz 10-08-2008 12:41 PM
There is a box but is a different one people usually have
Yes, there is a box, but there is only two holes and there was nothing behind it. No wood, no dry wall. It's all empty; that's the reason why I can't screw anything into it. There are two holes in the middle, but there are metal beind it blocking the way, so I can't scew anything there either. I added a picture of the box in the album. Please take a look it.
Marvin Gardens 10-08-2008 01:14 PM
Well I am not sure what is going on here as it is not all that clear.
If the light is small and doesn't weigh much you can use a retrograde box that will hold weight if installed correctly. These boxes have "wings" on them that will tighten up against the wall board and act as anchors.
jbfan 10-08-2008 01:28 PM
You will have to cut the screws to make them shorter. It happens all the time.
luvxyz 10-08-2008 02:46 PM
I think I know what you are refering to. Unfortunatly I have a havy light.
Termite 10-08-2008 04:06 PM
The box in the picture is a pancake box. It is a very common box, and is made of metal. What you need is a mounting strap (or "hickey") to accommodate the light fixture screws. The hickey screws to the box.
You should be using machine-thread screws...You are, right?
Termite 10-08-2008 04:09 PM
If the pancake box isn't secured to anything, it should be easy to remove and replace with a box that will physically mount to the sheetrock with the aforementioned little plastic wings. There are other configurations as well.
220/221 10-08-2008 05:42 PM
It's a pan box for a reason. There will be a stud behind it.
Like jbfan said, you just need the right length screws (8/32's) that won't hit the back of the box.
If that is a FAN pan box, the screws will be 10/32's and will slip thru the tabs and screw into the back of the box.
Termite 10-08-2008 06:30 PM
I'd certainly hope so too, but the OP indicated that there wasn't anything behind it.
220/221 10-08-2008 07:18 PM
He was confused :jester::jester::jester:
