Nortron Elecfric Furnace 21b25 - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 01:40 PM   #1
nortron elecfric furnace 21b25
furnace trips breaker every couple days checked voltage and amperage can't find problem. no burnt wires or smell from furnace any ideas on what problem could be
loicfeu is offline   Reply With Quote
Old 02-27-2009, 01:42 PM   #2
Rewards Points: 150
Old/faulty breaker? Hard to tell without knowing what the furnace draws and the breaker size you have now!
Gary
Gary_602z is offline   Reply With Quote
Old 02-27-2009, 01:50 PM   #3
nortron furnace
Breaker and furnace 2 years old at start up draws 88 amps then drops to77
breaker is 125 federal
Last edited by loicfeu; 02-27-2009 at 01:58 PM. Reason: forgot to incude breaker amperage
Old 02-27-2009, 02:08 PM   #4
How big are the wires? I seriously think this is too big for the furnace.
Federal? Which one? Is it the stab-lok type?
How to identify stab lok breakers.
http://www.inspect-ny.com/fpe/fpeid.htm
Probably a split bus panel...so what turns off when the breaker trips?
rgsgww is offline   Reply With Quote
Old 02-27-2009, 02:18 PM   #5
nortron furnace
sta block breaker wire size 2/2 300 volts
LOIC
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
