Northeast Flooding - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 03:47 PM   #1
Northeast flooding
Hi I am an industrial electrician in an area hit hard by flooding , so of course everyone calls me and ask what to do with the electrical box. I personally would replace any breaker under water at the least. I was wondering what are your thoughts.
Jj375 is offline   Reply With Quote
Old 09-10-2011, 04:02 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Tough call. To err on the side of safety, I’d say yes, replace the panel and breakers. On the other hand, I’ve seen panels and breakers submersed and dried out with no ill effects. Much of it depends on what is in the water that is getting deposited onto the panel and parts. As you may know, pure water is neither conductive nor corrosive. It’s the garbage in the water that cause conductivity and corrosion.
Kyle
Old 09-10-2011, 05:21 PM   #3
It's river water so it's going to be corrosive. Plus lots of mud left everywhere. I agree replace is the safest bet. It's hard to explain to people though it might work now. It could not work tomorrow.
Old 09-10-2011, 05:31 PM   #4
Licensed electrician
Rewards Points: 1,456
NEMA has a good paper on water damaged equipment. you can google for it, but it recommends replacement.
SD515 (09-10-2011)
Old 09-10-2011, 06:10 PM   #5
Thanks I just read it and it sums it up pretty good.
Old 09-10-2011, 06:22 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Good to know Michigan isn't the only place with dirty rivers
Did I just say that?
Kyle
Old 09-10-2011, 06:51 PM   #7
It's pretty bad mud sewage heating oil good mix plus a high iron content from all the mines.
Old 09-10-2011, 07:29 PM   #8
Code05's Avatar
Rewards Points: 1,104
Link for future readers.
http://www.nema.org/stds/water-damaged.cfm
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
SD515 (09-10-2011)
Old 09-10-2011, 08:21 PM   #9
Originally Posted by Code05 View Post
Thanks for posting that link. I did not have time to look it up. Trying to get yard work done while it wasn't raining for a change.
Old 09-13-2011, 05:59 AM   #10
There are bound to be all sorts of opinions on this, and recommendations. Then there's the NEC. My experience with our old (100A) electrical panel was that these things will take a lot of water. Our service was above ground, entering the house about 12-15 feet up, and for some reason, if a bad thunderstorm blew the rain against that side of the house, water would literally POUR out of the panel in the basement. Weatherhead on the thing must have been bad, I dunno. Anyway, that happened several times, and nary a breaker tripped. When we finally had to move to a 200A panel about 6 years ago (and we buried the service, so the water issue is gone), a lot of those breakers (C-H) were moved over. I've only had one of that batch fail outright, a 30A dual breaker to the oven.
rico567 is offline   Reply With Quote
Old 09-13-2011, 07:05 AM   #11
The trouble is that you don't know if the potentially damaged equipment will trip when you need it to trip.
Old 09-13-2011, 05:50 PM   #12
I get your point.....but circuit breakers are the type of mechanism that's just a "black box" to the homeowner anyway. The only way we have to test the breaker is to deliberately overload the circuit, and how many people are going to do that?
Old 09-13-2011, 08:43 PM   #13
That is why it is easier to just replace them.
Flooding in Wood Foundation mhp8982 Building & Construction 14 03-09-2011 01:15 PM
How do I Prevent Flooding KerryA. Building & Construction 8 11-16-2009 04:16 PM
Is having a sump pump an indication that the basement has a flooding problem? MCK Plumbing 7 08-24-2009 08:57 AM
Low-E in the Northeast. Clutchcargo Building & Construction 11 10-28-2008 07:34 AM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
