Is This Normal For A Dimmer Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 07:18 PM   #1
Is this normal for a dimmer switch??
I installed one of those dimmer switches with an on and off click button and a slider for dimming. It also has an LED light that is on when the switch is off.
So I wired it up and to test it, attached my multi-meter to the switched-hot from the switch and neutral wire (the leads that would attach to the load). I got a reading of 90 volts. So clicked the button, no effect, still around 90 volts. The line has no load on it. This was very strange to me so I replaced all wires in the path and tried again and the same thing. So eventually I attached a light to the end of the line. The light worked 100% and dimmed as it should. With the light attached testing with my multi-meter at the light socket, I get 120 volts when it is on and 0 volts when it is off.
So to sum it up the switch works 100% when there is a load on it (whether on or off).
I did check the output lines by touching them together when there was no light attached and I got no spark or anything, so the 90 volts that I am reading must be very low amps.
Is this normal for a dimmer switch???
slipgate is offline   Reply With Quote
Old 09-01-2010, 07:32 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,922
Yes, this is normal. The dimmer switch powers its internal electronics by leaking a small current through itself even when it is off. Since your multimeter has very high resistance, the "off" dimmer switch appears like a near short circuit and you read almost full line voltage in series with it. It behaves normally when you have a load on it, though, because the load resistance is much less than the dimmer's off-resistance.
mpoulton is offline   Reply With Quote
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 09:51 PM
Light doesn't turn on immediately on dimmer switch Michblaze02 Electrical 3 03-19-2009 05:14 AM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Dimmer switch quit working Umabean Electrical 4 07-09-2008 01:25 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
