Normal Amp Of Electric Oven (oven Only No Cook Top) - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 08:37 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Normal Amp of Electric Oven (oven only no cook top)
HI;
Still working on my parents house with my dad, that is progressing nicely, and I am starting to take some time to look at my own projects again.
I am going to put some EMT into my kitchen for the oven before I put the sub floor back down.
We are going to have a electric oven only, we will have a gas cook top. In terms of planing size of conduit / what else is going to go into the run back to the panel, I want to make an educated guess at Amps / wire size.
Do oven only units like this typically run on 30A / 10awg THHN? Or do they tend to still be up in the 40A range like typical electric oven/cooktop combos?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-10-2009, 09:47 PM   #2
Anywhere from 30-60 amps. Mine is on a 50 and is supplied by 6 awg. Maybe run the conduit and pull once you have the oven? Leave some room to float between 4 10 awg or 3 6s?
rgsgww is offline   Reply With Quote
Old 02-11-2009, 12:46 AM   #3
DIY'er
jamiedolan's Avatar
Thanks. I am glad I asked. I will run 3/4" over to be safe and pull once I have the oven in. I had no idea some of them pull that much.
Is yours a double oven or with a high power broiler that it needs so much power?
Jamie
Old 02-11-2009, 08:18 AM   #4
Jamie
I think its the broiler that pulls the most. I just read, and it requires a 40 amp breaker. 50 was in for upgrades I think.
Old 02-11-2009, 12:46 PM   #5
DIY'er
jamiedolan's Avatar
Thanks again
Jamie
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Replacing Electric Built In Oven handygirl37 Appliances 2 09-09-2008 09:38 PM
Converting Oven from gas to Electric MicMat Appliances 2 06-18-2008 06:00 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
GE freestanding electric double oven ssk Appliances 1 03-12-2008 01:12 PM
