Is This Normal? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 04:03 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by rgsgww View Post
Do you have a ground rod?
Why would this matter?
Old 09-19-2008, 06:43 PM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by skipjack View Post
I was just wondering about that too, joed. How do I know what end the charge is coming from?
Read this article
http://ecmweb.com/grounding/electric...uth_grounding/
Kyle
Old 09-19-2008, 09:53 PM   #18
Idiot Emeritus
Rewards Points: 1,492
Have you measured voltage across the open connection? In my experience, it's fairly common to have several amps of current flowing in a ground wire, but when it is disconnected, the voltage across it is low.
Just because it sparks doesn't mean there's dangerous voltage or current. There's a reason the code requires ground wires like this to be bigger than a lamp cord. There's more stray current flowing through the earth than you can imagine, and there's a good chance that in your case, even if you completely disconnect the electrical system from the building there'd still be enough current to cause a spark.
If it's less than 20 volts, and less than 5 amps, I wouldn't be any too concerned.
Rob
micromind is offline   Reply With Quote
Stove hood fan making noise when windy... normal? curls00 General DIY Discussions 7 12-17-2007 10:54 PM
Is oil smell normal when furnace ignites? skittlzski HVAC 5 11-30-2007 05:18 AM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 07:52 AM
converting sun room for normal use akhanf Building & Construction 1 04-24-2006 10:29 PM
Is a big price difference normal? chevyguy1973 Roofing/Siding 5 02-08-2006 10:06 PM
