Non-working outlet...
I have two non-working outlets, one in each bathroom. One has a GFI plug and the other has a standard outlet. I'm assuming that one is first in the circuit and that it continues to the second outlet, where the wires stop.
I swapped out the GFI for a standard outlet to test, still no power. So I tried a second standard outlet, no power. I swapped out breakers, still no power.
No power isn't entirely true, when I measure it with a meter it slowly climbs to about 20v. So if it's not the outlet and not the breaker, what else could it be?
I've checked the standard outlet in the second bathroom and it seems to be wired correct. Can any offer any suggestions? Thanks
