Non-working Cable Reed With Neon Light - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 09:11 AM   #1
Question
Non-working cable reed with neon light
Hi, nice joining diy chatroom. I have a cable reel witn neon light and 10m cable leght. the neon light comes on when connected to the main, but when i plug in iron or other appliances, it goes off. Can u help pls. Tx.
DIY.Willow is offline   Reply With Quote
Old 02-06-2009, 11:53 AM   #2
Rewards Points: 900
If I understand you correctly, you've got a receptacle/cable where you have indication with a neon test lamp, but when you plug in a load, the light goes out and you have no voltage.
If this is correct, you have an open circuit. The neon lamp will light even with an open, since it does not draw current, and reads voltage coupled by capacitance or a very high resistance in the cable or at a previous receptacle/junction.
Check other receptacles/lights on the same circuit. Most circuits are wired from one receptacle to the next, so you may have a broken connection at one receptacle.
If you can provide a bit more info, I am sure that I, or someone else here can help you.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-06-2009, 04:25 PM   #3
Yeah, coobe a broken wire internal to the cable.
You may find the break by flexing portions of the cable with a table lamp plugged into it. Most likely places are at each end of the cable where minimum bend radius cautions were not followed.
You may also localize the sparking at the break with an AM radio tuned between stations.
You can then fix it but you will then compromise weatherproofness and cable tensile strength.
Old 02-08-2009, 12:24 PM   #4
Rewards Points: 900
Do you ever wonder what happened to the OP when there's no response from him after a week or so?
Unsolved mysteries...
FW
Old 02-08-2009, 03:26 PM   #5
FW
Probably died a horrible death due to bad advice emanating somehow from his computer. Or not.
cable going outside for entrance flood light amakarevic Electrical 23 11-11-2008 12:42 PM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Light switches not working marc633 Electrical 7 07-22-2008 05:34 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
Light switch not working! jtbel Electrical 4 12-09-2006 06:34 PM
