-   -   Non-IC rated lighting in Insulated cieling. OOPS! (http://www.diychatroom.com/f18/non-ic-rated-lighting-insulated-cieling-oops-17220/)
MyMonkey 02-17-2008 05:11 PM
This is my first post. I read a bit here about IC vs. Non-IC Rated recessed lighting. Well, as it turns out, I installed 4 inch non-IC rated lights above my kitchen. :eek: Had no idea at the time they could not come in contact with the insulation. Anyway, I have tried to determine some way to insulate these things without replacing all of them. (8) Heat resistant foam came to mind but I don't want to burn down the house. I am stumped and believe I just have to replace them.
I do have access from above in the attic with some room. The problem is a few of them are right next to a rafter and there is no way the box for an IC rated housing will fit. Any ideas?
gregzoll 02-17-2008 05:21 PM
You will have to build boxes around them (aprx. 3 times the size of the fixture to allow for non-close contact), and then from there will have to insulate. Otherwise, get the correct fixtures, and fix it now, then doing it the other way.
And as for the boxes not fitting, fixtures can be rotated to allow for the box to fit, or look into Low Voltage fixtures, that use a remote transformer.
Pudge565 02-17-2008 10:23 PM
all you really have to do is keep the insulation at least 3 inches away from the light in all directions. this is cheap plus not labor intensive. only reason i know this is cuz we just went over this unit at vo-tech.
goose134 02-17-2008 11:37 PM
Pudge is right on. If you want to bury these cans then you'll have to build boxes. If, like in my father's house, a draft becomes apparent, then consider air tite trims. They are available at home centers. They don't look much different on the outside (which is good) but the cut down on airflow significantly. Good luck!
wire_twister 02-18-2008 09:13 PM
use some roof flashing formed in a circle and set down around the light to hold the insulation back at least 3 inches from the fixture. leave the top of the flashing ring open for air flow, some recessed fixtures have a thermal cut out in them when it gets too hot the light goes out, thermal cools and the light comes back on.
goose134 02-18-2008 10:00 PM
That's actually not a bad idea. Also thermal cutouts will open when the lamp wattage is too high for the fixture. Same principle.
MyMonkey 02-22-2008 10:02 PM
Thanks everyone. Great info. I like the idea of the flashing and the airtight trims. I will have to take another look but I think the cans actually have holes of some sort in them. Ugh!
goose134 02-22-2008 10:46 PM
When I say air tite trims, I believe it is a trade mark from HALO. They are by no means actually air tight, nor do the cans have to be. Take a look at the home center. I may be remembering the name incorrectly, but it's in that vein.
