Non Grounded Outlets In The Basement? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 01:51 PM   #1
non grounded outlets in the basement?
So I just got done changing out all the outlets on the ground floor of my 1963 ranch home. I went downstairs and changed a switch, and noticed that there was a ground wire in the electrical box. This got my interest because when we bought the home I thought the realtor told us that the basement was ungrounded. I took out one of the outlets and there is a ground wire along with two whites and two blacks. Can I just put in a grounded outlet since there is a ground wire in the box?
TableTiger1 is offline   Reply With Quote
Old 02-08-2009, 01:53 PM   #2
Electrician
What type of wiring method and where does this ground wire actually connect to?
chris75 is offline   Reply With Quote
Old 02-08-2009, 01:58 PM   #3
I am not really electrically inclined so I am not sure. There are two white wires attached to the left side of the plugs and two black wires connected to the right side of the plugs. The ground wire comes into the box in a big sheath with all the other wires. It is currently connected to a screw in the metal box. Not sure if that helps at all.
Old 02-08-2009, 02:00 PM   #4
Electrician
I think I would need a picture before I assumed anything...
Old 02-08-2009, 02:20 PM   #5
There are two separate wires going into the electrical box. Each has a white a black and a ground. Not sure if this pic does any justice. The ground wires aren't screwed in. The are just shoved into a hole in the bottom of the box.
Old 02-08-2009, 02:29 PM   #6
Electrician
Yeah, I wanted to see the inside of the box.
Old 02-08-2009, 02:29 PM   #7
Also I am getting shocked every time i touch any of the new switches i installed. I didn't attach the ground to the new switch as it was already attached to the metal box. We do have a lot a static electricity right now, but I am not sure if I did something wrong in installing the switches. They only had two wires and I just put them on the same way they were on the older switch. I am guessing it is just the low humidity in the air.
Old 02-08-2009, 02:35 PM   #8
Old 02-08-2009, 02:41 PM   #9
Yes. The ground wire must be attached to the metal box and to the grounding screw on the recep. You may have to install a small pigtail to accomplish this.
It's not that uncommon to have ground wires but ungrounded receps in that era. The ground wire is probably smaller than the insulated wires, but it's a ground.
New capret? A static shock feels completely different than a 120V 60 cycle shock. Figure out if it's static before we waste a bunch of time discussing the possible causes of an AC shock.
220/221 is offline   Reply With Quote
Old 02-08-2009, 02:46 PM   #10
It is most certainly not an electrical shock. I have been shocked that way before and it is much more painful than what i am experiencing. This is just static shock. I just wasn't sure if the new switches are making it worse somehow.
Thanks for the replies btw.
Old 02-08-2009, 02:50 PM   #11
Nylon cover plate screws are available if it persists.
Old 02-08-2009, 03:18 PM   #12
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Also screwless cover plates
http://www.ebuild.com/articles/509991.hwx
made by Leviton, P&S, & China
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-08-2009, 03:25 PM   #13
Is this something that I should be doing on all the switches and receptacles? When I redid the ground floor I just reattached everything on the new piece the way it was on the previous switch or receptacle. So if the ground was attached to the old piece i reattached it and if it wasn't and it was only connected to the metal box I just left it the way it was. Is this a problem? I think most of the switches had just the white and black attached and the ground was connected to the box by a screw. Some of the receptacles had grounds attached and some didn't.
Old 02-08-2009, 03:33 PM   #14
Switches in a metal box can rely on the mounting screws for gronding.
Receps require a ground wire attached to them.
Old 02-08-2009, 03:59 PM   #15
Electrician
Unless of course your using self grounding receptacles...
outlets in basement larryct Electrical 7 10-20-2008 07:53 PM
Basement finishing : Bathroom and Wetbar Outlets cderner Electrical 8 07-25-2008 06:27 PM
GFCI Outlets in Basement helpless handyman Electrical 4 04-20-2008 10:23 PM
Outlets are not grounded...what to do about it? OldHouse963 General DIY Discussions 10 04-14-2008 08:36 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
