Non-grounded Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2007, 07:54 PM   #1
Non-grounded outlet
I have a question...I am buying a house that has a three prong outlet that is not grounded (ground vault indicator test). What could be the reason for this? All the other outlets are OK.
jimmy v is offline   Reply With Quote
Old 12-27-2007, 09:31 PM   #2
Electrician philosopher
What is a "ground vault indicator test"? Need more info...could just be a loose connection of the ground wires in the circuit before it gets to those outlets.
Andy in ATL is offline   Reply With Quote
Old 12-27-2007, 10:12 PM   #3
Union Electrician
goose134's Avatar
It could be a couple of things. If it is an older home, ( by older I mean 19th century) it may be knob and tube wiring. The entire system has no raceway and no ground. If it is a home of more recent vintage, it may be a receptacle that has a loose or disconnected ground. Or it may be a DIY job that was botched along the way. Open it up and look into it. Let us know what you find.
goose134 is offline   Reply With Quote
Old 12-28-2007, 06:49 AM   #4
waiting for spring
arichard21's Avatar
Rewards Points: 150
Check the ground connection. Some people like to just twist the grounds together with no crimp or wirenut.
arichard21 is offline   Reply With Quote
Old 12-28-2007, 08:47 AM   #5
Rewards Points: 1,548
1. Flexible metal sheathed cable (such as BX) with two conductors inside is often passed off as grounded but it is not unusual for the bonding to be lost because the ends of the cables were not adequately clamped onto the junction boxes.
2. Twisted-only ground wires from Romex cables were common even into the late 20'th century. (My house was built in 1985 and has this.) Supposedly there were "twister tools" to get a better bond than hand twisting although I would not say that everyone used them.
Old 12-28-2007, 11:49 AM   #6
Rewards Points: 236
You may have only two conductors feeding the outlet. Maybe someone put in three prong and only had two wires. Look inside the box.
If it worked before you worked on it. You did something wrong.
J. V. is online now   Reply With Quote
Plugging power cord in a non-grounded outlet sil Electrical 4 10-18-2007 12:23 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
