Non-grounded To Grounded Adapter - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 12:03 PM   #1
non-grounded to grounded adapter
Hi. I have several strings of outdoor patio lights that I've daisy-chained together with the end of the line being a two-hole female non-grounded plug (both slots are the same shorter length than a polarized length). I want to plug into this end with either a two-prong grounded or 3 prong grounded, but can't find an adapter.
wilkc is offline   Reply With Quote
Old 06-15-2009, 12:10 PM   #2
Rewards Points: 2,350
I know you don't want to hear it, but unless you are plugging another string of lights in, don't do it. These things aren't made to carry a significant load, plus they are usually made to the poorest standards that the Chinese government will allow. Find another solution or install a receptacle for the purpose.
Old 06-15-2009, 01:18 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Here is the reply I made on another board this is posted to:
You will not find such an adapter nor would one be safe.
A) You will not have any ground available at all, so using one is not safe as anything 3-prong would need a ground to function safely.
B) The thin wire on those lights is NOT designed to carry any more current that two or three light strings.
Making a battery powered device work with an AC/DC adapter? FlyGuy Electrical 14 11-21-2010 07:28 PM
Pitless Adapter Submersible Pump Wild Blue Plumbing 5 08-31-2009 01:02 PM
Grounded electrode on water pipe TW Lucas Electrical 7 05-12-2008 11:33 AM
Removing 2" marble toilet flange adapter for handicapped proofer Plumbing 20 04-21-2008 04:31 PM
Outlets are not grounded...what to do about it? OldHouse963 General DIY Discussions 10 04-14-2008 08:36 AM
