Non-functioning Door Chime - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 11:44 PM   #1
non-functioning Door Chime
Hello,
I am restoring an old house and am trying to get the original doorbell/door chime to work. I replaced some old wires and tested the transformer with a multitester. It outputs 10+ volts as rated, and I get 10+ volts at the chime terminals when the doorbell is pushed. It just doesn't ring, which leads me to assume the chime is the problem. Does anyone know where I could get replacement parts for the chime. Any suggestions for the most likely malfunctioning part? Here's a pic of the chime.
FixingOlga is offline   Reply With Quote
Old 04-18-2009, 11:48 PM   #2
dSilanskas's Avatar
do you have a model or anything on the cover? Whay year was your house built?
dSilanskas is offline   Reply With Quote
Old 04-19-2009, 09:19 AM   #3
Household Handyman
Rewards Points: 1,408
Actually I would call this more of a "doorbell/buzzer" than a "chime". It's very similar to the one that was in my Grandparents house. Are you getting 10+/- volts at the two screws that are above the two coils in the picture? If you are, a problem with the coils are the most likely culprit at this point. Can you move the clapper arm manually? If you can watch to see if the two plungers within the coils are moving also, they should be. You might try to spray something like WD-40 on the plungers as you move the clapper arm back/forth to free them. There is also a good chance a coil or both coils have gone bad. Not much you can do there. You can still buy this type "bell/buzzer" at most big box stores, I put one similar to that one in my shop, although I'm thinking it was 12vDC. Good Luck, David
Old 04-19-2009, 01:54 PM   #4
dSilanskas's Avatar
If you want to buy really cool stuff from the era your house was built check out this site. You can buy just about everything from back in the day
http://www.rejuvenation.com/
Water heater not functioning. Not draining either? J187 Plumbing 2 04-12-2008 07:59 PM
Clothes dryer functioning but no hot air Squeeealer Electrical 3 10-03-2005 10:53 PM
