Non-contact Voltage Tester - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 12:28 AM   #1
Rewards Points: 506
Non-contact voltage tester
Lots of comments about this tool which fit two categories:
1. They are finicky and overly sensitive;
or
2. Do not trust them.
I'm curious if anyone here has ever experienced a tester which did NOT indicate voltage when it should have?
jlmran is offline   Reply With Quote
Old 07-09-2012, 12:52 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Anyone using any type of voltage tester should first test it on a known live circuit so you know it's working. I've used tick testers made by Ideal, Klein and other manufacturers. I always test them on a known live circuit first. I have yet to see one fail just after it passed the known live test.
You have to know how to use them. You can't wave them past a bunch of wires and learn anything when they indicate voltage. You have to separate out the wires first. You have to insert them in the hot slot of a receptacle. Etc. You have to be very precise with its use or you could get a ghost reading.
They are handy to quickly find out if there's voltage present. If you want to know exactly what's live or not, further testing with more precise instruments is required.
JulieMor is offline   Reply With Quote
Old 07-09-2012, 09:55 AM   #3
Rewards Points: 1,192
I learned if you have a voltage indication of a circuit you suspect is off,touch your finger on probe tip as you test wire.
bobelectric is offline   Reply With Quote
Old 07-09-2012, 11:41 AM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I had a Greenlee which had a nasty habit of turning itself off during use. So it would indicate no voltage on a live wire. It was almost brand new when it hit the garbage can.
John
jrclen is offline   Reply With Quote
Old 07-09-2012, 10:39 PM   #5
Rewards Points: 242
I've got a GreenLee GT-12...available at Lowe's...it works fine. I use mine all the time...and so far...it always detects voltage in a hot circuit.
Just make sure that you test it on a known good circuit as suggested by the manufacture.
Mine has a red LED that blinks when it's on...so...that's a good thing.
It chirps and beeps when it detects AC voltage...
Ed911 is offline   Reply With Quote
Old 07-09-2012, 11:49 PM   #6
Master Electrician
There's no substitute for a good old vol-con solenoid tester. The issue with a tickle isn't that it doesn't sense voltage. if its used right it will keep you safe like Julie said. The issue is the false reading you can get. Thinking somethings on when its not can really mess up your day. The part I don't like is that it doesn't pick up hot shared neutrals. Only way to cover your butt on that is a real tester.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-10-2012, 09:20 AM   #7
jrclen's Avatar
Rewards Points: 514
They have their place, but they do have their limitations too.
John
Old 07-10-2012, 10:11 AM   #8
Rewards Points: 160
I got a mid-priced one for about $15 at lowes and it works good. It's useful as another tool in verifying a circuit isn't hot. Although I always check it multiple ways such as verifying the outlet is dead, circuit breaker is off, etc.
matt151617 is offline   Reply With Quote
Old 07-10-2012, 06:35 PM   #9
jrclen's Avatar
Rewards Points: 514
As I say, they have their uses. But I would never trust my life to one. A good meter is the only verification I trust. And I've turned off many circuit breakers in my career, only to find out it's the wrong one. Be careful out there.
John
Old 07-10-2012, 06:36 PM   #10
Rewards Points: 150
Non-contact volt tester beeps before insertion
I frequently use a non-contact voltage tester wand to quickly tell me if an outlet has power. Usually I have to slide it in a slot to get a reading. On one of my rental properties I used it on some upstairs outlets, and it started beeping and the light came on when I was about 1 inch away from the outlets. In the downstairs outlets I have to slide it in as usual to get a reading. Does this mean anything?
I used a volt meter, and the upstairs outlets read 114 to 115.
Cossack is offline   Reply With Quote
What is causing a low voltage in my ceiling fan/light? rookies5 Electrical 12 01-25-2012 07:18 PM
Circuit Board Failure due to High Voltage huyer HVAC 5 01-07-2012 06:07 AM
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
