Non-contact Volt Tester Beeps Before Insertion - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 06:37 PM   #1
Rewards Points: 150
Non-contact volt tester beeps before insertion
I frequently use a non-contact voltage tester wand to quickly tell me if an outlet has power. Usually I have to slide it in a slot to get a reading. On one of my rental properties I used it on some upstairs outlets, and it started beeping and the light came on when I was about 1 inch away from the outlets. In the downstairs outlets I have to slide it in as usual to get a reading. Does this mean anything?
I used a volt meter, and the upstairs outlets read 114 to 115.
Cossack is offline   Reply With Quote
Old 07-12-2012, 04:48 PM   #2
Rewards Points: 150
There are no replies so can I assume it does not mean anything? This is the first time I have seen this happen, and it ONLY occurs in the upstairs of this particular house.
Old 07-12-2012, 04:56 PM   #3
MarginallyQualified
Rewards Points: 2,464
NCVT range between problematic ---> unreliable ---> useless
If you don't already have a plug in polarity tester... get one.
Old 07-12-2012, 05:39 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,852
Totally normal behavior.
mpoulton is online now   Reply With Quote
Old 07-12-2012, 06:50 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
You can make one beep by rubbing up and down your sleeve.
The Following User Says Thank You to jbfan For This Useful Post:
plummen (07-14-2012)
Old 07-12-2012, 06:55 PM   #6
Master Electrician
mine goes off randomly in my pants pocket while i walk at work
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-12-2012, 06:59 PM   #7
jbfan's Avatar
Rewards Points: 138
Bragging or complaining???
k_buz (07-13-2012)
Old 07-12-2012, 07:01 PM   #8
Master Electrician
both
Old 07-12-2012, 09:46 PM   #9
Rewards Points: 1,192
Hold your idex finger on the tip of tester to see if that makes it quit .
bobelectric is offline   Reply With Quote
Old 07-13-2012, 10:07 PM   #10
Rewards Points: 150
I have used this wand for a long time in many houses and it ONLY happens in this house in the upstairs room.
Old 07-13-2012, 10:46 PM   #11
Missouri Bound's Avatar
Non contact testers are prone to go off for no reason at all. Use a plug in tester for outlets, a wiggy for other testing. Non contact are not useless...they tell you there is power....somewhere.
Do you want it your way or the right way?
Old 07-13-2012, 11:39 PM   #12
Rewards Points: 506
"Useless" might be a little harsh. If anything they are overly sensitive...which means if you can't get it to beep, chances are the nearest voltage is 1/2 mile away. Yet, voltage (or lack of) should be verified with something more precise if the work involves handling potentially energized components.
jlmran is offline   Reply With Quote
Old 07-13-2012, 11:46 PM   #13
Master Electrician
they are particularly "not usefull" for testing unbalanced loads on neutrals. probably why most shocks come off the neutral.
Old 07-14-2012, 12:35 AM   #14
Rewards Points: 506
I thought the neutral conductor was used "after" the load?
Old 07-14-2012, 12:37 AM   #15
Mad Scientist
Just for S&G, you might want to check that particular outlet for a hot ground, or energized metal box. I've seen exactly what you're talking about in a house that had some outlets wired with a bootleg ground and reversed polarity. On the normal outlets, I'd have to get the probe at least *near* the hot slot on the receptacle to get a beep. On the outlets with electrified grounds, the beeper would go off anywhere near the receptacle.
Always verify strange readings with a voltmeter, using an extension cord plugged into a known good outlet as a reference point if necessary.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
mpoulton (07-15-2012)
Non-contact voltage tester jlmran Electrical 9 07-10-2012 06:36 PM
Need advice on whats the best non contact voltage tester humberguy Electrical 16 12-31-2011 03:37 AM
Buying an electrical outlet costing .99 cents vs. $3.00 Mikon8er Electrical 40 11-20-2011 12:01 PM
how to make a 208 volt plug-in tester michael m Electrical 4 06-23-2011 11:12 PM
