Noise Interference - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 06:54 PM   #1
noise interference
when I turn on my fluorescent lights, my radio hums real bad. How can I stop the noise interference? thanks
pooldaddy9 is offline   Reply With Quote
Old 08-25-2011, 07:01 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Common complaint from garage guys...
Are they new lights?
If Lithonia....give customer service a call....word has it that they actually do care.
Otherwise....just make sure the ballast and metal enclosure is properly grounded.
The Following User Says Thank You to ddawg16 For This Useful Post:
pooldaddy9 (08-26-2011)
Old 08-25-2011, 07:52 PM   #3
they are new lights. The ground was the first thing I checked because it is a metal building. I checked the antena on the radio to make sure it was tight. Doesn't seem as bad but noise still there. Thought radio shak might have something but the store here is slack.
Old 08-25-2011, 08:27 PM   #4
Rewards Points: 1,548
Radio stations come in much more weakly (if at all) in a metal building. The radio circuitry self adjusts to some extent to better pick up weak stations but in so doing the interference from the fluorescent light is accentuated.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 08-25-2011, 10:09 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,610
Your radio signal must be weak,
So signal to noise ratio is bad,
You probably did not notice it before,
Try using an outside antenna.
This will improve the sig/noise ratio.
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 09:05 AM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 09:16 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
TV interference when devices are turned on or off in the home - ideas? rightbryce Electrical 7 09-19-2009 11:43 AM
