Old 12-30-2010, 11:47 PM   #1
no wiring for the central vacuum
The central vacuum was partially installed without the wiring and then closed over with sheetrock. Is there any way to make it work without having to fishh the wire down through the walls to the outlet?
mgamike is offline   Reply With Quote
Old 12-30-2010, 11:52 PM   #2
nap
You talking to me?
nap's Avatar
short of manually going out and turning on the remote unit when you want to vacuum, none I can think of.
Old 12-31-2010, 08:45 AM   #3
Master Electrician
What is missing? Line voltage low voltage or both? Some systems have line voltage at the vacuum outlet some do not.
brric is offline   Reply With Quote
Old 12-31-2010, 08:48 AM   #4
A "Handy Husband"
rjniles's Avatar
If you do not wish to fish the low voltage wiring to each location you might consider an X-10 home automation system.
You would need 3 components:
A 3 wire appliance module to plug the vac into.
http://cgi.ebay.com/X10-15A-GROUNDED...item5d2983c6ad
A transceiver to accept wireless signals from a hand held remote.
http://cgi.ebay.com/X10-TWO-WAY-TRAN...item255dc77168
A hand held remote.
http://cgi.ebay.com/X-10-SLIM-FIRE-P...item5d24f637b8
These items total about $22 including shipping. Plug the vac into the appliance module. Turn the vac's switch on and let the appliance module control the power. Plug the transceiver into a centrally located electrical receptacle. Carry the remote to turn the vac on and off.
I am not associated with the supplier I suggest but have used in the past and they are very good.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 12-31-2010, 09:00 AM   #5
An appliance cord with a plug on it (also an extension cord) may not be fished in a wall.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 01-03-2011, 02:45 PM   #6
For any central vacuum with a low voltage failure, simply use this remote clicker to turn on the vacuum.
centralvacman is offline   Reply With Quote
Old 01-03-2011, 03:22 PM   #7
A "Handy Husband"
rjniles's Avatar
$213 plus shipping Sounds like the poster has a vested interest- I go with my $22 X-10 solution.
Old 01-03-2011, 03:47 PM   #8
He may, but it is still a viable option.
Remember, your solution is switching the line voltage power source while his is switching the low voltage circuit which is the way the vacuum is supposed to be operated. Can you guarantee that your method will not harm the vacuum? Some people are willing to pay in order to do something correctly instead of with makeshift items pieced together.
BTW, the module you suggested won't be able to handle most central vacuums.
General is offline   Reply With Quote
Old 01-03-2011, 03:55 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Without knowing the type of system you have it is hard to give an accurate answer.
It would be nice if you came back to check your replies. From your status I see you left the minute you posted this (four days ago) and have not been back since.
Old 01-03-2011, 04:05 PM   #10
A "Handy Husband"
rjniles's Avatar
The appliance module can handle 15 amps. If you want to control it on the low voltage side, use an X-10 Universal Module which can supply a contact closure rated at 5 amps @24VDC
http://cgi.ebay.com/X10-UNIVERSAL-MO...item255e68a7fb
Old 01-03-2011, 04:12 PM   #11
Ampacity isn't everything, check the HP rating
As for the rest of your post, I already answered that. ("Some people are willing to pay in order to do something correctly instead of with makeshift items pieced together.")
Old 01-03-2011, 04:18 PM   #12
nap
You talking to me?
nap's Avatar
well, if that were the case, he wouldn't be here looking for solutions. He has a solution and that is to install the proper wiring but that would require that "pay in order to do something correctly" thing you were talking about. OP doesn't seem to be interested in that.
Old 01-03-2011, 04:24 PM   #13
Running the proper wiring might easily cost more than $213.
But my reply wasn't really to the OP, it was about the justifiable high cost of a piece of warrantied production equipment vs. some X-10 stuff pieced together from eBay and other online sources.
Old 01-03-2011, 04:33 PM   #14
nap
You talking to me?
nap's Avatar
what difference does it make if it is more or less than $213. Your statement was:
You put no limitation on the actual cost. Doing it correctly would be putting the wire in the wall like it's supposed to have. To me, anything less than that is cobbling it together.
and using an x-10 unit (if properly sized and I have no idea what they offer) would be nothing different than the "warrantied production equipment". the x-10 devices are intended to be used to control power to appliances. That would make it also "warranted production equipment".
Old 01-03-2011, 04:41 PM   #15
The difference is that you said the OP wasn't willing to do it correctly and buy the $213 devide because he wasn't willing to pay to have it wired. I refuted that by saying it might cost a lot more than $213 to rewire it, he could do it correctly with the linked to device for $213.
This just happened minutes ago, pay more attention to what you post...
Sure it would be much different.
Not when the recommended equipment both switched the power supply which could be harmful to the vacuum and isn't sized correctly to even be used with a central vacuum.
You can argue all you want. Have fun!
Central Vac Wiring Dar Electrical 10 02-27-2009 05:22 PM
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 01:59 PM
Testing a Central Vacuum with no hoses or heads MrLinux General Discussion 1 01-23-2008 04:44 PM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 10:23 PM
re-routing central vacuum pipe yummy mummy Building & Construction 2 12-03-2006 05:30 PM
