No Switch For Motion Detector Flood Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 07:38 PM   #1
Rewards Points: 1,062
no switch for motion detector flood light
i was wondering if it is legal to not have an indoor switch for a flood light that has a switch on it and a motion detected on/off.
thanks
Old 10-31-2011, 07:53 PM   #2
Code05's Avatar
Rewards Points: 1,104
A switch is not required, yet it is a good idea. Not only can you turn it off when not needed, you use the switch to make it stay on when you want it to.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
amakarevic (10-31-2011)
Old 10-31-2011, 08:06 PM   #3
you can actually do that on most fixtures as well.
Old 10-31-2011, 08:19 PM   #4
Missouri Bound's Avatar
amakarevic...do you mean a disconnect for the fixture or a switch to override the motion detector?
Old 10-31-2011, 08:32 PM   #5
disconnect for the fixture -- i haven't seen a fixture that would allow a switch to override its motion detector
Old 10-31-2011, 08:38 PM   #6
A disconnect isn't a bad idea, it most often occurs when a regular fixture is changed to a motion detector type.
Old 11-01-2011, 10:10 AM   #7
The two motion detectors we have allow the switch the override the motion detector. Turn ON-OFF-ON within 3 seconds allows the light to stay on as long as you want. When you turn it OFF and back ON, it resumes using the motion sensor.
brgmgb is offline   Reply With Quote
The Following 2 Users Say Thank You to brgmgb For This Useful Post:
amakarevic (11-01-2011), Code05 (11-01-2011)
Old 11-01-2011, 12:47 PM   #8
that's neat. would you mind to check the brand on that light and let me know? it would be greatly appreciated.
Old 11-01-2011, 12:59 PM   #9
Code05's Avatar
Now do understand my post?
Old 11-01-2011, 01:01 PM   #10
Code05's Avatar
Every motion sensor light I have installed had the override feature.
Go to the store and read a few labels.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
