No Square D QO 2-pole CAFCI Breakers - Options? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 11:46 AM   #31
Electrical Enthusiast
Rewards Points: 504
Originally Posted by k_buz
That requirement should have taken effect as of 1/1/14.
Hooray!
Kyle_in_rure is offline   Reply With Quote
Old 01-31-2014, 02:52 PM   #32
Rewards Points: 336
Originally Posted by gregzoll View Post
Not even in the OP situation. Especially if a Sub-Panel is being suggested. My guess is that their existing panel is filled to capacity, is thy the AHJ suggested putting in a sub.
If you read the thread you will see that this is not the reason a sub-panel was suggested.
JKeefe is offline   Reply With Quote
The Following User Says Thank You to JKeefe For This Useful Post:
Kyle_in_rure (01-31-2014)
Old 01-31-2014, 07:39 PM   #33
Rewards Points: 6,652
If you took the time to read the thread, I am very aware of the OP situation.
Old 01-31-2014, 08:03 PM   #34
Rewards Points: 336
I did...
Old 02-03-2014, 11:46 AM   #35
FIDO...
Rewards Points: 241
Eaton/CH has 2-pole CAFCIs...
This info probably isn't much help to the OP, but for others watching this topic, Eaton/CH does currently have 2-pole CAFCI breakers available.
I recently upgraded my CH panel to (almost all) CACFI breakers, and that's how I discovered I had a MWBC setup for my kitchen. Very admittedly, I should've caught that in my pre-breaker-swap panel review & check-out, but I somehow missed seeing that one old 1-pole breaker that happened to have no neutral. I simply overlooked it - no excuses.
Long story short, I can absolutely confirm that you CANNOT replace the 2 regular 1-pole breakers that may currently be powering your MWBC with 2 1-pole CAFCIs - I learned that the hard way after figuring it was perhaps worth a try... Fortunately, no permananet damage done, and valuable lesson learned!
I was lucky to discover that Eaton/CH has 2-pole CACFIs available, and that worked like a champ on the MWBC once I popped it in.
I've had all the new CAFCI breakers working well for several weeks now - no nuisance trips at all on any of them.
Cheers, Chris
Chris130 is online now   Reply With Quote
Late 70's square recessed ceiling lights - replacement options? CZSteve Interior Decorating 1 07-26-2013 11:26 AM
Can a T104 dual pole timer be used as a single pole installation? illuminate Electrical 6 06-13-2012 05:33 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 10:23 AM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 06:08 PM
