No Square D QO 2-pole CAFCI Breakers - Options? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 12:58 PM   #16
Rewards Points: 6,652
There is a picture of the Square-D CAFCI on the Structure Tech Home Inspections Face Book Page, along with the new Square-D panel.
The test button is Purple on the Square-D CAFCI breaker.
Old 01-30-2014, 01:23 PM   #17
Double-pole? Square D has single-poles, I know that (my Home Depot has a large supply), but they don't have double-poles yet.
IGx89 is offline   Reply With Quote
Old 01-30-2014, 03:48 PM   #18
Go to an Electrical Warehouse, not Home Depot for what you need.
Old 01-30-2014, 04:51 PM   #19
I believe I found the post you were talking about (January 18th?), but they're "QO Plug-on Neutral CAFI" breakers and not shared-neutral/double-pole breakers -- completely different things I think?
The Following User Says Thank You to IGx89 For This Useful Post:
gregzoll (01-30-2014)
Old 01-30-2014, 06:04 PM   #20
More info on them. http://www.schneider-electric.com/pr...cuit-breakers/
Old 01-30-2014, 10:21 PM   #21
Electrical Enthusiast
Rewards Points: 504
What a waste of money really....
Kyle_in_rure is offline   Reply With Quote
Old 01-30-2014, 10:51 PM   #22
Actually not. It is saving money. You will start seeing MWBC more common with these newer panels. Cuts down on costs & maintenance.
Give me five years, and I am switching over to the new QO Panel, since I have maxed out my current QO panel that I had installed back in 2003, when we bought this place.
I cannot wait for the panels & corresponding CAFCI's to become available, soon enough.
Old 01-30-2014, 11:18 PM   #23
Rewards Points: 504
Originally Posted by gregzoll
Actually not. It is saving money. You will start seeing MWBC more common with these newer panels. Cuts down on costs & maintenance. Give me five years, and I am switching over to the new QO Panel, since I have maxed out my current QO panel that I had installed back in 2003, when we bought this place. I cannot wait for the panels & corresponding CAFCI's to become available, soon enough.
I should have clarified, I was referring to the OPs situation.
Old 01-31-2014, 08:02 AM   #24
Not even in the OP situation. Especially if a Sub-Panel is being suggested. My guess is that their existing panel is filled to capacity, is thy the AHJ suggested putting in a sub.
Old 01-31-2014, 10:38 AM   #25
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The panel has nothing to do with the functionality of 2 pole AFCI breakers.
Old 01-31-2014, 10:41 AM   #26
k_buz's Avatar
The OP's panel is not maxed out. He can't find any 2 pole AFCI's from SQ D.
The sub is the simplest way to go.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (01-31-2014)
Old 01-31-2014, 10:52 AM   #27
Licensed electrician
Rewards Points: 1,028
I am sure the inspector suggested the sub panel as it is about the only option available to the OP since a two pole Square D is not available.
Old 01-31-2014, 11:11 AM   #28
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
This situation is why many people (and some electricians) would not get a permit for this type job. It is beyond reason to require an upgrade to AFCI given the particulars of this job.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 2 Users Say Thank You to rjniles For This Useful Post:
gregzoll (01-31-2014), Kyle_in_rure (01-31-2014)
Old 01-31-2014, 11:57 AM   #29
Think this is bad, wait til a receptacle needs to be replaced that needs AFCI protection.
Old 01-31-2014, 12:16 PM   #30
k_buz's Avatar
That requirement should have taken effect as of 1/1/14.
Late 70's square recessed ceiling lights - replacement options? CZSteve Interior Decorating 1 07-26-2013 12:26 PM
Can a T104 dual pole timer be used as a single pole installation? illuminate Electrical 6 06-13-2012 06:33 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 11:23 AM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 10:05 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 07:08 PM
