Old 11-06-2011, 03:46 PM   #1
No sound from speakers on rear projection tv
i have a rear projection tv about 55". last night i was watching a DVD through the AUX jack (sound worked just fine) this morning i woke up and i had picture BUT no sound. what i tried so far was...
-disconnected cable box and ran cable from TV to outlet (no sound)
-switched to AUX mode to play DVD (no sound)
-checked sound settings to make sure it was on STEREO not mono (no sound)
-made sure it was NOT on Dolby (no sound)
FINALLY- hooked AUX cable (red & white) from TV to home stereo (no sound)
IT SEEMS LIKE I TRIED EVERYTHING I JUST NEED TO SEE WHAT IM MISSING..ANY HELP WOULD BE THE BEST!!!
chewizzle2k9 is offline   Reply With Quote
Old 11-06-2011, 03:50 PM   #2
JOATMON
ddawg16's Avatar
Rear projection? Sounds like it's 10+ years old.....
Also sounds like you hit all the obvious things.....
Get if fixed or buy a new flat panel that will take up a lot less space.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-06-2011, 05:30 PM   #3
Will it allow you to increase the volume with the remote?
(My TV has a setting that if you send sound through the back plugs, it turns off the sound totally on the built in speakers. And you can't raise the volume on the TV.)
Other than that, go through every audio menu item and see if anything works.
I have these problems when my dog steps on the remote! I have no idea what she presses, but I spend forever trying to get things working again. I've learned to turn the remote upside down...
Billy_Bob is offline   Reply With Quote
Old 11-06-2011, 07:41 PM   #4
seansy59's Avatar
It may be out of your experience, but.....
Same thing happened with an old tv I had. When the RCA cables or headphone cable was plugged in, the built in speakers went off, and I would hear a click. One day it stopped, and it was all silent. Turned out to be the sound relay switch the finally fried/broke. $2 part at RadioShack, and I soldered a new one on! Works fine to this day.
But, this is from a person that repairs, collects, and refurbs audio equipment, so I kinda know what to look for.
seansy59 is offline   Reply With Quote
Old 11-06-2011, 10:42 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Can you post model & manufacturer of the set? If it is RCA input, a lot of time it could be just a setting such as TV sound off, set volume is lowered, who knows, but you.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Toshiba theaterview rear projection tv - wierd sound noquacks Home Theater 5 03-02-2012 12:04 AM
No sound from speakers on rear projection TV noquacks Home Theater 3 10-08-2010 06:29 PM
best way to wire rear surround sound speakers brewmastr Electrical 5 01-10-2010 07:37 AM
Surround Sound Speakers Blondesense Home Theater 3 11-26-2009 08:42 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
