No Sheath Round 12/3 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 07:18 PM   #1
Installing an outside outlet about one foot away from present(inside) receptacle(outlet). In the process of pulling the black, white and ground wire into the outletI I pulled the sheath off. I went ahead and installed receptacle(outlet) which works fine. Is there any concern about leaving the wires unsheathed in the wall? Please advise.
TFSpaniel is offline   Reply With Quote
Old 07-24-2011, 07:47 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Yes pull a new piece in. The sheathing is there for a reason. One being to keep the wires next to each other so their magnetic fields will cancel each other out, reducing inductive heating of the wire insulation. Suggest stripping the sheathing of a new piece on both ends and taping the sheath to the wires a little before pulling it in. Should help keep it on.
Kyle
Old 07-24-2011, 11:19 PM   #3
Thanks for the advice. I will have to remove the wires from the outlets(ugh) and begin with a new piece of 12/3. I cannot get to this right away but will do it tomorrow. I do not plan to use these outlets for the present time i.e. nothing plugged in.
Old 07-24-2011, 11:25 PM   #4
Learning by Doing
Leah Frances's Avatar
Even with nothing 'plugged in' you should kill the circuit until you fix it. Just in case you don't get to it tomorrow
It will be safer and it will remind you to fix it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-25-2011, 04:55 AM   #5
Rewards Points: 1,192
I can only guess you have a black,a white,and a bare copper which is a 12/2 nm. I agree with the other responders that say redo it because it isn't an approved wiring raceway/metheod.
bobelectric is offline   Reply With Quote
Old 07-25-2011, 08:32 AM   #6
One last question! I still have the unblemished sheathing that was pull off the three wires. It can easily be slid back on the wires connecting both outlets. Would that be adequate?? And yes I have killed the circuit until I can alleviate the problem.
Old 07-25-2011, 01:28 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,858
I can't think of a reason not to. As long as it's just like it was originally, it seems fine.
mpoulton is offline   Reply With Quote
Old 07-25-2011, 06:56 PM   #8
Could not thread the sheath through the access hole. Scrapped that idea and went back to square one and used a clamp. Only took 'bout an hour and half. Amazing when you do things over how much quicker things go.
Thanks for all the advice. Now maybe my house won't burn down. Ha!
I just love this site and those who participate!
Old 07-25-2011, 07:06 PM   #9
Learning by Doing
I just love this site and those who participant!
Hip Hip Hooray for doing it right, even if it wasn't the first time. It's how we learn, after all.
Old 07-26-2011, 07:02 AM   #10
Rewards Points: 720
Inductive heating of the insulation? The only time inductive heating is an issue is if there is a ferrous material between the conductors. Otherwise, you can separate them as much as you want without a heating issue (see old K&T installations), but there would be a code issue. Separating conductors can cause EMI problems also.
Mark
busman is offline   Reply With Quote
Old 07-26-2011, 09:46 AM   #11
Nice to know. Next time that should happen(no sheath) I will not worry but I do feel better with the sheath intact on the second try.
Old 07-26-2011, 12:15 PM   #12
Rewards Points: 720
I didn't say that no sheathing is fine. It is a problem. It just has nothing to do with inductive heating.
Mark
Old 07-26-2011, 01:24 PM   #13
Just curious but what are the negatives in that situation?
Old 07-26-2011, 03:41 PM   #14
Mad Scientist
It'd be illegal, which is usually enough of a reason. Most of us just won't endorse something that "technically" works fine, but doesn't meet code. It's a liability thing, yanno?
McSteve is offline   Reply With Quote
Old 07-26-2011, 04:28 PM   #15
Learning by Doing
It's Really Really bad DIY Karma to do dangerous/not to code work.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
12/3 wire with ground srudyv Electrical 40 01-02-2011 05:20 PM
Red wire is HOT genner Electrical 15 02-22-2009 09:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
