No Power To Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 03:24 PM   #1
No power to receptacle
I have a single receptacle in my shop. It has no power but the circuit wasn't tripped. The only two services on this box are overhead lights, which work, and the receptacle. The receptacle is directly below the box, with no exposed wiring. What could it be?
russpowell is offline   Reply With Quote
Old 09-10-2011, 03:36 PM   #2
Journeyman Wireman
Rewards Points: 150
How are you testing the receptacle to determine it's not working? Do you have any testing equipment like a multi-meter or Wiggy type tester?
Could be:
bad breaker
bad connection at the receptacle
problem somewhere else that you aren't aware is part of that circuit
tripped GFCI ahead of the receptacle (located in another part of the house)
tripped breaker that doesn't look tripped.
Give us more information about what you have done to troubleshoot the problem.
Jupe Blue is offline   Reply With Quote
Old 09-10-2011, 03:45 PM   #3
More info
The shop is standalone, 50 feet from the main residence. I only changed out extension cords to see if they were bad. I don't believe there is anything else up line of this. A single power source feeds to the shop from the house and there are two circuits.
Old 09-10-2011, 04:09 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Is the breaker that feeds the shop a 2-pole breaker? Try turning it off then back on. If your shop is being fed 240V or is a MWBC, you may have 'dropped' a leg coming from the house. Sometimes a 2-pole breaker will trip internally, but not trip the handle or the other leg.
Kyle
Intermittent Brief Power Outages in Half the House mac70pete Electrical 11 06-02-2011 09:35 PM
Restoring power to detached garage alexmce Electrical 4 05-31-2011 05:27 PM
Making a waterproof/weatherproof enclosures for a network camera & its power hub snowfall Building & Construction 0 05-02-2011 10:14 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
