No Power To Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 10:58 PM   #1
no power to pool
We had a huge storm earlier in the week and now there is no power to my pool. The pump and filter will not turn on. We tried to reset the breaker but it did not help. I really dont want to have to call someone to look at it . Anyone have any ideas. Please help.
tfmurray2 is offline   Reply With Quote
Old 08-24-2012, 11:20 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Did you try to reset the GFCI breaker or GFCI receptale there should be a reset or test switch to test it.
If you have the GFCI breaker turn the handle all the way to off postion and push little more than normal so it can latch on and turn it back on if that do not work either GFCI breaker or GFCI receptale is toasted if you have power surge that useally kill them.
Merci,
Marc
pool "current" pipefitter Electrical 60 09-20-2011 07:50 AM
Intex Pool goes underground arbizval Building & Construction 5 06-05-2011 08:34 AM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
post next to inground pool RJoe Building & Construction 1 08-01-2010 04:46 PM
