No Power To Outlets And Ceiling Fans In Living Room And Master Bedroom? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 04:37 PM   #1
No power to outlets and ceiling fans in living room and Master bedroom?
We had a brief power outage all power went off and then back on instantly. I don't know if this was related but I believe it was the same or next day we noticed the outlets off. I have checked and reset all breakers and GFCI outlets. None were not tripped and are not on the same circuit as the ones with the outage I think. Any help on trouble shooting I am pretty handy, have a DMM outlet tester plug in. There are at least 2 outlets and ceiling fans out in each room. TIA
boneglove is offline   Reply With Quote
Old 03-18-2011, 05:15 PM   #2
hkstroud's Avatar
Rewards Points: 1,572
Suggestion;
Remove one of the non-working outlets. Check to see if it has been wired using the "quick connect" holes in the back. If so, rewire using the screw terminals on the side. The "quick connects" are notorious for developing poor connections over time.
The bad connection maybe at a non-working outlet or it could be at the last outlet on that circuit that works. The bad connection may be on the hot (black) or the neutral (white).
hkstroud is online now   Reply With Quote
Old 03-18-2011, 05:26 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
with so much out I suspect a breaker. Sometimes the breaker handle can stick in th on position even tho it is off. If reseting the breakers does not solve the problem then you have a loose or broken connection near the beginning of the circuit.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-18-2011, 05:34 PM   #4
Just discovered while checking outlets it says hot and neutral reversed. I recently moved a mirror, pretty long nails, could this be it?
Old 03-18-2011, 05:45 PM   #5
Licensed electrician
Rewards Points: 996
Did the move of the mirror happen at the same time you lost the power?
Old 03-19-2011, 03:24 AM   #6
I'm not sure but definitely within a day or so of the move
Old 03-22-2011, 02:30 PM   #7
Have not checked the outlets that are out for loose wires yet. Should I or is there something else one could suggest?
Old 03-22-2011, 05:14 PM   #8
Scared Electrician
hire a professional
Old 03-23-2011, 11:39 PM   #9
I fixed it YEA!!!
Old 03-24-2011, 12:22 AM   #10
Rewards Points: 506
Originally Posted by boneglove
I fixed it YEA!!!
How??
jlmran is offline   Reply With Quote
Old 03-24-2011, 03:46 AM   #11
I tracked down the outlets that were off to their breaker, and checked the motion detector light outside. The wire splice in the fixture did not have tape on it!!!!! And must have touched shorted. Took light off as I'm replacing them and not immediately, but after a few minutes it worked. Thanks to all for advice. Saved some bread on that one.
Old 03-24-2011, 04:00 AM   #12
Scared Electrician
All Right!!!
Old 03-27-2011, 08:32 PM   #13
hkstrod helped the most but yea I see what you mean. Any help at all is appreciated! It's free after all! Thanks.
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
