No Power At Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 06:17 PM   #1
No power at outlet
I have a 15 amp 125 volt outlet with a hot black wire but no power coming from the outlet. I changed the outlet with a new one but still same problem. Any ideas?
furdur is offline   Reply With Quote
Old 12-19-2009, 06:20 PM   #2
Ok do you mean you have one set of wires, a black wire, a white wire, and a copper wire?
Paelectrican is offline   Reply With Quote
Old 12-19-2009, 06:22 PM   #3
300zx's Avatar
Post
If the wire (Black) is hot then you lost your Neutral Wire somewhere go to the closest outlet abd pull it out and check your wires
300zx is offline   Reply With Quote
Old 12-19-2009, 07:28 PM   #4
Yes. I have one black, white and copper wire. I will check the neutral on the nearest outlet which unfortunately is the TV/entertainment and behind the armoir and not light. All of that is working correctly. When you say that I "lost" that wire, are you saying that it is not connected properly to the outlet at the TV? There may be a J-box in between those two and will check that as well.
Old 12-19-2009, 07:32 PM   #5
Yeah go back to the last working outlet on that run and make sure all is hooked up right. That is likely gonna be where your problem is. Have you used a meter to check between you ungrounded and grounded conductors or between your ungrounded conductor and ground?
Old 12-19-2009, 07:48 PM   #6
I do not have a voltage meter to check. I have a voltage detector which only shows the black wire as hot with nothing on the white. I have a circuit tester that plugs in and no lights come on.
Old 12-19-2009, 07:51 PM   #7
alright, go back to the last working receptacle on that run and see if everything is hooked up right, you likely have a bad connection.
Old 12-19-2009, 08:14 PM   #8
Will do. Thank you for your help.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Power Outlet & Power Inlet same box? theatretch85 Electrical 4 10-18-2009 03:37 AM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 06:27 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
