No Power And No Breaker Tripped Temporarily - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 09:26 AM   #1
Question
No power and no breaker tripped temporarily
So here is a strange one. Hopefully someone can help me out. Last night I went into my basement and turned on the lights (high hats). Then I turned on the TV. I saw one of the high hats flicker. Didn't think much of it and turned on the cable box. About 2 seconds later the whole side of the basement lost power.
I went over to the electrical panel and saw NO breakers tripped. I turned off the breaker that I thought it was, thinking it may reset itself. Let it sit for a while and this did nothing.
I went to bed thinking, time to call an electrician in the am. When I went downstairs this morning I had power again. Very strange.
Questions:
1-Anyone have a reason why this would happen?
2-Do I call someone in now to be on the safe side?
Any answer/recommendations are greatly appreciated!!!!
jritkes is offline   Reply With Quote
Old 06-16-2011, 10:54 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Loose connections somewhere.
You need to map out the circuit and find it.
It could be in a receptacle, or a switch, or a j-box for the can lights.
jbfan is online now   Reply With Quote
Old 06-16-2011, 01:05 PM   #3
Rewards Points: 320
A lot of times people will use the holes in the back of receptacles instead of wrapping the wire around the screw terminal. The wire can pop out of these holes and create an intermitent failure or just remain out causing an open circuit. I second jbfan, figure out what's on the circuit and if you have power now, turn off the breaker while you go about pull devices out of their boxes. If you can find the start of the circuit that's where i'd start seeing as how everything went off when you had a problem and not certain things. Well I guess you said just half the basement lost power so if you know which object holds the break in the circuit between things working and things not working that'll be a good bet to hold your problem.
autx790 is offline   Reply With Quote
Loss of power and AFCI tripping Sacslc Electrical 14 11-14-2010 09:12 PM
No power, not the circuit breaker PCMLR Electrical 3 10-10-2010 08:22 PM
Power on several circuits comes and goes all at once, never trips breaker Michael H Electrical 22 06-29-2009 08:22 AM
Power out/circuit breaker good robertsbuchanan Electrical 3 06-26-2009 10:15 AM
Breaker problem jdhar Electrical 11 06-10-2009 01:18 AM
