No Power At Live Feed To Bathroom Wall Heater. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 12:13 AM   #16
Electrical Enthusiast
Rewards Points: 504
I was under the impression that the OP meant it was a "pull cord" switch.
Kyle_in_rure is offline   Reply With Quote
Old 02-16-2013, 12:32 AM   #17
" Euro " electrician
frenchelectrican's Avatar
Either that or possiblty bad plug as far we know with heaters are famous for that ( it don't matter if Americian or European verison the answer always the same )
Merci,
Marc
Old 02-16-2013, 04:38 PM   #18
FRENCHELECRICIAN.
Sorry but it was nothing to do with the cord pull switch or the heater itself. The original problem was with the mains live feed being dead. Now live !!
barwen18 is offline   Reply With Quote
Old 02-16-2013, 11:59 PM   #19
Originally Posted by barwen18 View Post
FRENCHELECRICIAN.
Then you have loose connecton at the main board that something you will have to check it out and tighten it down.
If you are not confortable doing this then hire a electrician to come out and assit you on the repair.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
barwen18 (02-17-2013)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Second hotwater heater installed in bathroom? Snav Plumbing 3 02-28-2010 10:05 AM
