No Power At Live Feed To Bathroom Wall Heater. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 01:28 PM   #1
No power at live feed to bathroom wall heater.
Hi,
I am hoping you can help me with a problem I am having with my bathroom wall fan heater.
My bathroom wall fan heater was clogged with dust etc and as a result it tripped the mains circuit breaker as it was getting quite hot. After cleaning the fan I switched on the breaker at the main fuse box and all electrics came back on apart from the wall heater. I removed and replaced the small fuse which is situated on the heater switch but still no power. I removed the switch cover and put a test lamp to the live feed which is coming from the loft. It did not light up. I went back to the main fuse box (modern type) and all fuses are in the on position ? Every light, socket and other appliance in the house is working. So how is it that there is now no live feed only to the heater. I was an apprentice electrician for two years so I have a basic knowledge and I know I am checking the right cable etc. Please help.
barwen18 is offline   Reply With Quote
Old 02-13-2013, 01:48 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by barwen18 View Post
I removed the switch cover and put a test lamp to the live feed...
I went back to the main fuse box (modern type) and all fuses are in the on position?
Are they marked? Do you know WHICH circuit feeds the heater?
Once you are certain which... can you test the voltage past the breaker to see if the line is being given voltage to begin with?
The Following User Says Thank You to TarheelTerp For This Useful Post:
barwen18 (02-13-2013)
Old 02-13-2013, 01:55 PM   #3
Rewards Points: 1,538
Built in heaters are usually 240 volt and have two breakers or fuses in the main panel or fuse box. The fan may work if only one of the breakers is on but the heater needs both breakers to be on. Double check and turn each breaker off and then back on to reset it correctly.
There could be a loose connection in the wiring between the panel and the heater.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 02-13-2013, 02:12 PM   #4
Thanks to both of you who replied.
It does not have its own circuit breaker in main fuse box. Fuses marked are the usual cooker, immersion heater, seperate up and downstairs lights, and one for all sockets.
I have switched off and on all breakers and fuses but still no live feed from loft cable to heater. The heater was working this morning but had started to smell a bit so that is why I cleaned fan blades. When I pulled the cord to turn back on the whole house went down and like I said before the main RCB had tripped but funnily enough the other breakers on each side of the fuses were still in on position. Could there have been a break in the cable ? but no signs of burning apparent at the heater side.
Old 02-13-2013, 03:44 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would be wondering where it got it's power if it only tripped the main and no other breaker tripped. Is there another panel somewhere in the attic or basement?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
Old 02-13-2013, 03:47 PM   #6
MarginallyQualified
It does not have its own (marked) circuit breaker in main fuse box.
Could there have been a break in the cable?
It *could* be many things.
You have to determine what circuit is supposed to feed the appliance.
If it is a shared circuit... then what else is on it?
At that point it's on to the poking about.
Trace the line back to the last known good spot.
Old 02-13-2013, 05:23 PM   #7
Thanks but no definitely no other panel. I have just been up in the loft and traced the cable right back across to just above the mains where it disappears through the ceiling and straight into and behind the new type main fuse box.
It is really baffling. No other appliance is affected just this loss of feed through this one cable. I cannot see how it could have become loose at the mains end not simply after me working on the heater fan end. I have repeated knocking off and on all trip switches and still nothing.
This is a fairly recent fuse box (4 months) and is not like the older one I had where I could get to the back of it and rewire to a spare. Would it be safe for me to tap into the shower junction in the loft and rewire from there ?
I know the fan heater is ok as I have just attached an extension cable from a normal plug socket to the heater switch to check and it worked no problem.
Old 02-13-2013, 06:06 PM   #8
Electrical Enthusiast
Rewards Points: 504
Do you happen to be in the UK? The terms you use make me ask.
Kyle_in_rure is offline   Reply With Quote
Old 02-13-2013, 06:10 PM   #9
Yes Uk ?
Old 02-13-2013, 07:44 PM   #10
Rewards Points: 504
I doubt it would be legal to tap into the electric shower, if that's what you have.
From reading I've done those things usually have their own circuit.
Just wondering, can you tell if the live feed from your fuse box goes to the heater and THEN to the switch, or two the switch first and then the heater?
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
barwen18 (02-14-2013)
Old 02-13-2013, 11:37 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Kyle.,
I know the OP is from UK which that is correct due he did mention that.,
Now it is illegal to tap to the electrique shower heater that have to be it own circuit per UK Reg 17 edition.
Now to the OP.,
There is possiblty a hidden spice block behind the new fuse housing. A real legit UK sparky will know this is illegal to have hidden splice block behind that location.
Try to trace that cable if that change colour or possible a broken cable you will have to double check for burnt mark on the cable.
And be aware between red et black also brown et bleu conductors pay attetion to them.
Merci,
Marc
Old 02-14-2013, 06:45 PM   #12
1
Thanks for your reply.
No, the live feed enters through the bathroom ceiling directly into the box which has a separate fuse at the front and also a flick down on off switch next to the fuse. Then a very short link cable from that box drops directly into the fan heater which has a pull down on off cord.
The dead feed is the actual cable running from the mains to the box above the heater.
Quote 2
There is possibilty a hidden spice block behind the new fuse housing. A real legit UK sparky will know this is illegal to have hidden splice block behind that location.
Regarding the hidden spice box. I have never heard of one and cannot look behind the new fuse housing as it is secured closely and tightly fitted within a very small housing but that sort of thing sounds possible as what else could stop the live feed as like mentioned all trip rcds etc are on and every aplliance, socket and light fitting are fine.
I will not tap into anything like advised so unless anyone can say for definite I suppose its going to be hand in pocket and get a sparkie in !
Old 02-14-2013, 06:53 PM   #13
Rewards Points: 504
It will be interesting to see what the problem was.
Old 02-15-2013, 05:16 PM   #14
Hi,
Well a very interesting thing happened this morning!
I was using the bathroom and considering what to do next to solve the problem regarding the dead live feed. For some reason I pulled on the cord and bingo the heater burst into life ? I immediately turned it off then on and off and it works. Now I can undersatnd if there was a thermal type cut out within the fan that had needed to cool down but as there was definitely no power coming from the live feed from the loft I am at a loss. Is there any chance that my new fuse box (4 months old) has some kind of individual thermal type circuit that would have now cooled. As stated before I was an apprentice electrician for a couple of years way back but I certainly was testing the live cable and not the heater side??? Any ideas on this one?
Old 02-15-2013, 11:30 PM   #15
Did you say that you pull the cord if so then you have loose connection at the power socket ( receptale or plug ) you will have to check it closer to make sure it is not loose or burnted if burnt you may want to cut off little peice of bad conductor off and refit with new power socket as the same size and type as the old one is.
Merci,
Marc
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Second hotwater heater installed in bathroom? Snav Plumbing 3 02-28-2010 10:05 AM
