No Power To Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 02:34 PM   #1
No power to light switch
My first post so thanks in advance.
I replaced outlets and 1 light switch in my son's bedroom and one of the outlets had a lamp plugged in an is operated by the one switch. All the outlets work except the light switch so I tested the wires with a multimeter and I am not getting any readings. I also checked the outlets and i'm able to get a reading. I hope this all makes sense. Please help!
mlascano is offline   Reply With Quote
Old 09-05-2013, 02:42 PM   #2
joed's Avatar
Rewards Points: 12,922
Was the receptacle only half switched? Did you break the tab between the screws on the gold side.
Old 09-05-2013, 02:51 PM   #3
Thank you for your reply.
I replaced the light switch with a Decora switch but when I removed the old switch I have to push in a small lever to release the black and white wires. Hope that helps.
Old 09-05-2013, 02:57 PM   #4
An old Tradesmen
Rewards Points: 7,388
Move to Electrical forum.
Old 09-05-2013, 03:32 PM   #5
DIY staff
Rewards Points: 7,174
I bet you threw out the old outlets already----if not look at them all and see if one of them has the gold tab removed between the gold screws.
That switch---what color wires go to it?
Does your house have Romex wiring or conduit?
mlascano (09-06-2013)
Old 09-05-2013, 04:21 PM   #6
JuzRick's Avatar
Mlascano: Did you rewire the switch, receptacle the same way you saw it before you changed it?
How many wires coming into the switch elect box?
It could be possibly a loose connection, or reverse neutral(meaning depending how many conductors you have coming into your switch), the white wire is your hot and the black is the switch leg.
But indeed if you can recall how many wires was coming in to the switch that's a start.
JuzRick is offline   Reply With Quote
Old 09-06-2013, 04:24 PM   #7
Oh mike,
I finally figured out what you were explaining about that tab because it was broken off of the old one and I did the same to the new one and IT WORKED!!! Thanks you so much! Just curious as to what the tab is for??
Thanks again!
Old 09-06-2013, 05:54 PM   #8
joed's Avatar
It's so you can make the receptacle half switched just like you have.
Old 09-06-2013, 06:26 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by mlascano View Post
Oh mike,
Thanks again!
The tab interrupts the power supply.
So one outlet is always hot and the other is only hot when the switch is in the on position, when wired correctly.
sublime2 is offline   Reply With Quote
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 09:07 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
no power to light switch and all breakers good mjsoma Electrical 4 10-02-2010 09:03 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
