Old 11-16-2012, 03:39 PM   #1
No power light switch.
I have multiple light switches that have no power to them. The breaker for them is showing 120v. please help
Billy T III is offline   Reply With Quote
Old 11-16-2012, 05:28 PM   #2
And you have shut off the breaker and turned it back on?
Looked for a GFI that's tripped?
There also going to need to know have you been doing any new wiring?
Adding a ceiling fan, changing a light fixture?
Old 11-16-2012, 05:28 PM   #3
Well, let's start with some questions.
1. How do you know which breaker provides poser to the switches?
2. Is this situation something that has always been so or has something happened or changed?
3. Are there other outlets or lights that are powered from the breaker that you have identified? If so, do they function properly?
czars is offline   Reply With Quote
Old 11-16-2012, 09:28 PM   #4
found the problem thanks. it was a disconnect at a junction thank you to all who replied
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
no power to light switch and all breakers good mjsoma Electrical 4 10-02-2010 10:03 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
