No Power In House - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 06:16 AM   #16
more info
Yes, they are all ungrounded outlets. And yes, I am using a tester at each outlet and light fixture. I have an electrician on standby. He told me to change out the receptacles first, since so many are in bad condition with green corrosion on copper wire, and rust on the screws. How do I test each circuit? Don't I need to know the diagram? The house is 50 years old with a new breaker box. The new wiring at the breaker box goes to a J box inside the house. I haven't done anything in there, but maybe I should see if there are any loose wires.
I also found several splices in receptacles with ancient electrical tape. Could that suffer moisture damage like the exposed copper wire did? Thank you for all the great ideas.
kirp1968 is offline   Reply With Quote
Old 06-10-2012, 06:38 AM   #17
DIY staff
Rewards Points: 7,174
I would start testing at the breaker box first---are both legs coming into the box live?
110 v each when tested to a ground--220 when tested together---
then test each fuse and breaker to ensure that there is power from the source,
Many of the taped connections in an old installation are soldered---of so--they seldom fail--but test them to be sure.
I am not a licensed electrician---they will correct me if I steer you wrong---Mike---
Old 06-10-2012, 06:40 AM   #18
DIY staff
Is the house wired with conduit? Greenfield? Romex?
Old 06-10-2012, 02:12 PM   #19
follow up
At the breaker box, all circuits show to be live, so I'm thinking the problem is possibly where the previous electrician forgot to connect something at the J box in the house. I have 4 more 3way switches to change out tomorrow morning, so that might help. But I doubt it. Seems the circuit for the bath, hall, and two bedrooms is failing. Oddly enough one of 4 outlets in the bedrooms is working, but the lights are not, nor is the entire bathroom or hallway.
Old 06-10-2012, 04:52 PM   #20
DIY staff
Could be as simple as a tripped gfci---
Old 06-10-2012, 05:15 PM   #21
dmxtothemax's Avatar
Rewards Points: 5,166
You said some things work !
And others dont !
Correct?
Have you identified whick breakers in the panel
control which circuits ?
If so you can start at the begining of each faulty line
and trace it out, to see where it goes astray !
Can yo do this ?
Posting a picture of your main panel opened will help !
dmxtothemax is offline   Reply With Quote
Old 06-10-2012, 10:39 PM   #22
more info
There are no GFCI outlets in the house.
About tracing it: In the new breaker box, one circuit seems to be the issue. The one market bathroom, hall, bed2 and bed3. There is power at the box for this circuit. Then there is new wire from the breaker to the old j box in the house. Can I turn all the breakers on and then test where the old wires meet the new wires to see which one has no power? Unfortunately, there is no way to crawl around in the ceiling to do any checking. I can poke my head into the area up there in one closet, but it's too small to get into.
Old 06-10-2012, 10:50 PM   #23
Once you have positively identified the supply circuit in the j box,
Try to follow it or trace where it goes,
Turning the other circuits off could make this a little easier.
Even if you just poke your head up into the ceiling
you might be able to see where the wires go!
Then try to find the other end,
and weather there is power there, or not !
If you keep following it,
you will find out where it is going astray !
Tags
electrical , no power
Getting power from new addition to existing house champ Electrical 4 10-13-2011 09:48 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Need Help! Lost power to half of house meganlaney Electrical 3 11-12-2010 06:26 PM
Lost Power to all of my outlets throughout house allie74 Electrical 5 04-15-2010 01:32 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
