No Power Going To The Light Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 12:38 PM   #16
Originally Posted by 220/221 View Post
But FIRST......Make sure the fixture has a bulb that you KNOW works. Screw it into a lamp and test it.
I'm glad that someone mentioned the light bulb!
If the switch is improperly wired, and is connected on the neutral side of the feed, then you will not get any voltage at the switch (on or off) if the light bulb is burned out!
FW
fw2007 is offline   Reply With Quote
Old 09-05-2008, 10:45 PM   #17
baseballfan's Avatar
sorry guys i didn't answer back sooner, busy working. i still having had a time to look at the problem, but i got some good answer from you guys, i will have to look at the light fixture connection, and just in case i will go get another switch, but don't think it is the switch. since no power going to the switch box. so will check the light fixture like i read in one of the past post. i am off this weekend so i will work on it. thanks guys
baseballfan is offline   Reply With Quote
Old 09-05-2008, 11:04 PM   #18
Electrician
SD515's Avatar
Rewards Points: 504
Hey BBFan
Good to see ya back. Good luck and keep us updated...and of course feel free to ask if ya need help.
Old 09-08-2008, 06:35 PM   #19
well thanks all you guys for your suggestions. i fix the problem i had to remove the marrettes (3 of them) and found this paste like stuff, at first i thought it could be tape that some how melted but i know that it doesn't, lol, why would they use thing like that and what is it anyways. anyways i cleaned it out and put new marrettes and voila it works. so thanks for suggesting to check the light fixture. now i got another problem nothing to do with electricity it is my fu**ing foundation it is crack i already posted a thread for that.
thanks guys.
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 03:33 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
3 Way Switch Draw additional Power? mattyd Electrical 15 03-24-2008 02:36 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 06:45 PM
