No Power To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 03:54 PM   #1
vla
no power to garage
Will a non GFI outlet stop power to an area? I bumped a night light plugged into the garage outlet, it flickered and then all power to gargage went out. Circuit breaker did not trip
vla is offline   Reply With Quote
Old 09-08-2012, 04:02 PM   #2
Rewards Points: 746
Just bumping it should not cut off the power.
More likely a wire came off, especially if they are back stabbed. If you feel able, turn off the power and remove the outlet. Check for loose wires.
If you aren't sure you have the power off, don't do anything without getting a tester OR even better an electrician.
AandPDan is offline   Reply With Quote
Old 09-08-2012, 04:28 PM   #3
Insatiable Learner
Rewards Points: 166
Post
If it's not a loose wore as mentioned above, then check to see if you have a separate sub panel just for the garage. Depending on how old your house is it might have its own small fuse box dedicated just for the garage area.
AngelArs is offline   Reply With Quote
running power to detached garage Roundeye Electrical 10 11-30-2011 10:05 AM
Wiring power to detached garage, more questions WillK Electrical 17 04-24-2011 01:48 AM
Wind Turbine for Garage Power? jpearson311 Electrical 4 04-12-2011 04:08 PM
power to my garage toddman0 Electrical 3 11-27-2010 11:10 PM
garage door opener power handifoot Electrical 4 11-23-2008 08:30 PM
