No Power To The Furnace. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 06:47 PM   #1
No power to the Furnace.
I seem to be having more trouble with this furnace. Now it doesnt have any power. It was running fine this morning, but this evening it stopped. I went down to it and noticed there was no power. I checked the fuses all checked out fine (Going into town tomorrow to get more fuses just in case.) Other then that I checked to power from the fuse box to the one unit it checked out 120 v. From there I went to the one for the chip panel and I didnt get anything. Did the switch go bad? I'm not all that sure. Any help would be great!
Hawkeye40 is offline   Reply With Quote
Old 11-05-2012, 06:55 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Most furnaces have a disconnect, usually a standard switch. I would look to see if that was accidentally turned off.
Old 11-05-2012, 07:16 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hawk you did not say anything about what type Thermostat?
  1. Mercury Contact (older style)
  2. Mechanical Contact
  3. Digital
  4. Electronic Programmable
There is also a Line Voltage type.
These kind of Problems can more often be solved with a picture.
Compare it to seeing the doctor or asking him to diagnose you by E-Mail.
Can you include a Pic?
If You don't know how, Give a shout-out.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-05-2012, 08:05 PM   #4
It is a mercury thermostat what i dont get is it was working today
Old 11-05-2012, 08:21 PM   #5
I checked that which made me think it was a bad wire but it read 120 v when I hooked up my volt meter.
Old 11-05-2012, 08:27 PM   #6
k_buz's Avatar
You checked what? the switch/disconnect? the t-stat?
What are you using to check for power?
Old 11-06-2012, 02:28 AM   #7
" Euro " electrician
frenchelectrican's Avatar
see below for correct comment
Last edited by frenchelectrican; 11-06-2012 at 02:34 AM. Reason: fixed the comment plus computer trick moi
Old 11-06-2012, 02:33 AM   #8
That part is fine so let hold that for a moment what brand furance you have there ? More details will help us to give us a idea what to do with troubleshooting.
But for myself one of few most common curpit is bad transfomer which I have see it once a while but just be aware they look simauir to the doorbell transfomer but the voltage and wattage is differnt the the common doorbell transfomer is ( HVAC units useally run with 24 volt secondary side with 40 Va rating but some are more larger depending on model itself )
The circuit board most case they usealy have a fuse there so if blowen you may have to replace the fuse but one warning if that fuse blow again do not do any thing else more just call in the HVAC tech there is few special prodcure the HVAC tech have to go thru to make sure nothing else is damaged.
Merci,
Marc
Old 11-06-2012, 05:36 AM   #9
It's a Nordyne not sure of the model. I'll be taking a trip to get a fuse today hope that settles it. The fuse didn't look like it was blown but never know.
Old 11-06-2012, 05:37 AM   #10
The transformer? Gonna have to look at some layouts then I'm not all that sure what it looks like
Old 11-06-2012, 06:10 AM   #11
Resi EC
Rewards Points: 252
Is this a new home?
Since you're talking fuses I'll guess older home.
Do you have a fuse with the disconnect for the furnace? SSU switch
Gac66610 is offline   Reply With Quote
Old 11-06-2012, 07:55 AM   #12
Rewards Points: 150
Here's a picture of some typical transformers. Sometimes the transformer itself will be mounted inside a small enclosure.
Dave632 is offline   Reply With Quote
Old 11-06-2012, 08:26 AM   #13
Thanks, I found it luckily I'm not sure though if that is the problem. Could a bad transformer completely kill all the power?
Old 11-06-2012, 08:33 AM   #14
Rewards Points: 150
In older homes, the primary use was to provide low voltage AC to the thermostat (rather than have the thermostat switch 120V). Nowadays, with more sophisticated control systems, it could also be used to produce the low voltage DC that most semiconductors require.
But I don't think that feeder power (coming from your fuse panel) would be affected. The furnace wouldn't work, but it would have power.
Old 11-06-2012, 08:50 AM   #15
Dave,
So what your saying is the furnace still has power its just the transformer is not allowing it to be on? If that is the case then I'll start looking for a new one. Gotta act quick apparently we are getting a Noreaster here. Of course the wife is complaining.
furnace power wiring question w/photo pirateplow HVAC 1 12-17-2011 06:32 AM
Furnace fan power consumption? DIYGST Electrical 5 04-19-2010 01:00 PM
Gas Furnace Power Venter Problem JoBlowHomeOwner HVAC 6 10-17-2009 09:05 PM
furnace or electrical help tuasoi Electrical 13 11-29-2007 12:53 PM
furnace and or electrical problems tuasoi General DIY Discussions 4 11-29-2007 12:50 PM
