Old 02-06-2012, 11:55 AM   #1
No power in all three bathroom outlets
We just moved in to our new house on Saturday. It was built in 1998, 3 bathrooms. The switches are fine but no power in outlets of all of 3 bathrooms.
Yesterday, I opened the electric box outside of my house, switched off then on all of them. Results same.
Please help.
hpdad is offline   Reply With Quote
Old 02-06-2012, 12:00 PM   #2
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Tripped GFCI or GFCI breaker?
rrolleston is offline   Reply With Quote
Old 02-06-2012, 12:01 PM   #3
J. V.'s Avatar
I found one GFCI receptacle feeding two baths and one outside receptacle. Find each GFCI receptacle and reset each one until you find the one that is tripped.
The Following 2 Users Say Thank You to J. V. For This Useful Post:
hammerlane (02-06-2012), hpdad (02-28-2012)
Old 02-06-2012, 01:18 PM   #4
Are the three bathrooms on more than one circuit (use more than one breaker)?
Measure the voltage between hot (the breaker screw) and neutral (the panel terminal strip for the white wires) for each applicable breaker.
Any other dead circuits or receptacles or lights about the house?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
hpdad (02-28-2012)
Old 02-06-2012, 06:15 PM   #5
biggles's Avatar
check at the outlets to the plate screws and or piping to see if your reading 115v to them .might be missing a neutral into the area
The Following User Says Thank You to biggles For This Useful Post:
hpdad (02-28-2012)
Old 02-06-2012, 10:02 PM   #6
analogmusicman's Avatar
Please help.
the GFCI in my garage feeds all the bathrooms and the 2 outside outlets.
tnx,
analogmusicman is offline   Reply With Quote
The Following User Says Thank You to analogmusicman For This Useful Post:
J. V. (02-07-2012)
Old 02-07-2012, 11:01 AM   #7
Yesterday after work, I looked in my garage to find GFCI outlet but I had found none. Oh, the three outlets in my three bathrooms looked normal ones, not with red button in the middle like GFCI.
Got home too late last night and it was dark outside. Will check again this weekend. Will welcome anymore suggestion.
Old 02-07-2012, 11:46 AM   #8
that means there *should* be a GFI somewhere that is tripped.
Techy is offline   Reply With Quote
Old 02-07-2012, 11:48 AM   #9
J. V.'s Avatar
I would put money its a tripped GFCI. There is to much coincidence. All 3 bathrooms. An easy simple find. And the OP is going to wait until this weekend.
Old 02-07-2012, 01:20 PM   #10
Al right, tell you the truth, I don't know where to look. I looked GFCI receptacle in the garage but didn't see one. Please give me some hints.
Old 02-07-2012, 03:47 PM   #11
look in all unfinished areas-around sinks-outside of the house-outside of your service panel. there may be one hiding somewhere. if not you may have a bad breaker, splice in one of the boxes or a bad neutral. it is probably a simple fix.
pokey is offline   Reply With Quote
Old 02-07-2012, 05:19 PM   #12
hmm...don't know if garbage disposers have to be gfci protected,but if they DO, your gfci may be hiding near that disposer. if it IS,track down the electrician and shoot him!
tnx,
hpdad (02-28-2012)
Old 02-13-2012, 11:58 AM   #13
I found two GFCI outlets: one in the garage and one at the kitchen sink (they all have power). Reset both, still no power on bathrooms's outlets. Any helps guys.
Old 02-13-2012, 12:05 PM   #14
Licensed electrician
Look in the garage, outside or a powder room or near the panel.
Old 02-13-2012, 01:57 PM   #15
liscenced electrician
This is why I never put gfcis protecting one room inside another room. Put aseperate gfci in each bathroom and don't connect anything to the load side on each one
jimmy21 is offline   Reply With Quote
Can just adding new electric wiring for new outlets increase power usage? elocs Electrical 35 09-22-2011 05:37 PM
bathrooms and outdoor outlets not working maybecalifornia Electrical 1 03-04-2011 07:24 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
bathroom power switches relative to bathtub amakarevic Electrical 7 10-14-2008 04:07 PM
outlets lost power Hoegy Electrical 5 11-06-2007 03:06 PM
