No Power To 2 Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 05:37 AM   #1
Rewards Points: 16
Question
No power to 2 outlets
Hello,
I had a over the stove microwave installed 2.5 years ago and it was working fine until a couple of weeks ago. I originally thought the problem was the control panel as the microwave would not go through the time entered on the control pad without shutting down but yesterday I discovered when the over shut down and did not turn back on that it was the electrical outlet that the installer added when they installed the oven. I changed the outlet but nothing happened. I also noticed that there was another outlet on the same wall in the kitchen that was dead as well. I guess he must have tied into that outlet for power. I check all my circuit breakers and they all look good. What would cause the 2 outlets to be dead? I do not understand why 2 outlets would be on a breaker by themselves.
Thanks,
Glenn
Partsman41953 is offline   Reply With Quote
Old 02-07-2011, 07:52 AM   #2
Licensed electrician
Rewards Points: 1,294
A loose connection can cause a whole string of receptacle to go dead. You will nned to find out where the installer grabbed power from for the microwave. This receptacle may still work, but the outgoing connection is bad.
BTW, this microwave should have been on a circuit all by itself.
Tags
breaker , circuit , outage , outlet , power
Electrical Outlets with Very Low Power goph27 Electrical 6 01-28-2011 09:26 AM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 03:06 PM
Power to outlets but not enough? batesrt Electrical 5 02-04-2008 10:12 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
