No Power - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 01:37 PM   #1
Mlwhite's Avatar
Rewards Points: 29
No power
I came home last night and found that I had no power in the basement. The breaker is not tripped! Any thoughts??
Michelle
Mlwhite is offline   Reply With Quote
Old 10-16-2011, 01:47 PM   #2
I=E/R
a7ecorsair's Avatar
No power, does that mean lights and receptacle and only those in the basement?
a7ecorsair is offline   Reply With Quote
Old 10-16-2011, 01:48 PM   #3
Mlwhite's Avatar
Rewards Points: 29
Yes no lights or outlets.
Old 10-16-2011, 01:54 PM   #4
I=E/R
a7ecorsair's Avatar
Do you know if the basement has its own circuit?
Did you actually turn the breaker off and then back on to make sure it is reset?
Are you aware of any GFCI receptacles anywhere in the basement?
Old 10-16-2011, 01:56 PM   #5
Mlwhite's Avatar
Rewards Points: 29
Yes it has it's own circuit. Turned it off and the back on. No gfci on the circuit.
Old 10-16-2011, 02:05 PM   #6
I=E/R
a7ecorsair's Avatar
You will first have to verify if you have power coming out of the breaker. You will need a meter and you will have to remove the panel cover.
Turn off the main breaker while you are getting set up. Once the cover is off and before turning the main back on, check wire where it is attached to the breaker and make sure it is secure and also locate the white neutral that is paired with the black wire and make sure it is secure in the neutral bar. If those are good you will need to check the voltage at the output of the breaker.
Old 10-16-2011, 02:40 PM   #7
Mlwhite's Avatar
Rewards Points: 29
Connections were good. 120v coming out at the breaker.
Old 10-16-2011, 07:18 PM   #8
I=E/R
a7ecorsair's Avatar
You will have to start opening up each receptacle and light fixture and look for the loose connection. Start with the ones closest to the breaker panel.
Old 10-16-2011, 07:44 PM   #9
Rewards Points: 6,652
Who wants to put bets on either a bad outlet, or tripped gfci.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
frenchelectrican (10-18-2011), Speedy Petey (10-16-2011)
Old 10-16-2011, 08:28 PM   #10
Code05's Avatar
Rewards Points: 1,104
My money is on a back stabbed device.
Code05 is offline   Reply With Quote
Old 10-16-2011, 08:30 PM   #11
I=E/R
a7ecorsair's Avatar
I did all the up front work so I get 50%
The Following User Says Thank You to a7ecorsair For This Useful Post:
gregzoll (10-16-2011)
Old 10-16-2011, 08:40 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I'd bet on a tripped GFI, but since all we know is that he has all the lights and receps on a single circuit in the basement of a mystery house all bets are off.
Location?
Age of the house?
Age of the basement wiring?
How many of each is on the circuit?
Old 10-16-2011, 08:58 PM   #13
Code05's Avatar
Location?
Age of the house?
I think OP maybe is a she. Michelle in post #1.
Old 10-17-2011, 05:44 AM   #14
I was testing you to see if you were paying attention.
Old 10-17-2011, 06:10 PM   #15
Mlwhite's Avatar
Rewards Points: 29
Thanks for all your help. It was a light fixture that was the issue.
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 10:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
